Replacing Coolant Hoses
Old Jul 3, 2002 | 12:15 PM
AKABILLY's Avatar
Question Replacing Coolant Hoses
Hey guys, I'm planning on replacing my upper and lower radiator hoses over the long weekend. The upper should be a snap, but the lower looks like a real bitch. Does anyone have any advice on the best way to tackle the lower hose? Should I go after it from under the car? While I'm at it should I use any kind of chemical to flush out my radiator?
Any advice...
Old Jul 3, 2002 | 01:12 PM
Silkworm's Avatar
Has been.. hangin' around
I've never used any Chemicals to flush my radiator, just ran water through the engine for a while..
The lower hose can't be accessed from below unless you remove the undertray. That's only a few bolts, but not sure if it's worth it.
Me, I'd take a razor knife to it
PaulC
Old Jul 3, 2002 | 01:19 PM
selanne8's Avatar
i was lucky, mine came off without too much trouble. i got mine off going from the top instead of through the bottom.
when you put the new one on though, apply little bit coolant on the hose mouth to help slide the hose in...it isn't all too hard to put in, just a little awkward.
john
Old Jul 3, 2002 | 03:44 PM
Aaron Cake's Avatar
Engine, Not Motor
Also, be sure to scrape all corrosion and gunk off of where the hose connects or you will get leaks...
Old Jul 3, 2002 | 03:46 PM
AKABILLY's Avatar
Anybody use Prestone radiator flush? Are any of these flushing agents worth it?
Old Jul 5, 2002 | 12:38 PM
AKABILLY's Avatar
Bump
Old Jul 5, 2002 | 12:50 PM
Aaron Cake's Avatar
Engine, Not Motor
Good 'ol vinegar works wonders on/in crustry rads. Of course, you need to disconnect the rad from the engine to use it...Fill the rad completely with vinegar, let sit a few hours, then rinse with water until clear.
HDA
Nov 3, 2015 03:49 PM
rotor_veux
Aug 31, 2015 07:49 PM
sYnth.
Aug 19, 2015 06:27 PM
LMBTG
Aug 15, 2015 01:43 PM
