Poor Idle troubles(info??)
Old Jul 3, 2002 | 11:07 AM
The 7's Avatar
Angry Poor Idle troubles(info??)
87* NA
The car is jerking at steady rpm when im moving
And now it is idling rough too???
it straightens out if i rev it up a bit but then it will go
back to the rough idle after a while???
Also it is making a throuty sound i have never heard before???
Could it still just be my TPS???
Any ideas
Thanks much
Old Jul 3, 2002 | 12:35 PM
The 7's Avatar
Seriously i could use some help with this one guys!!!
i have to try to fix it once i get home from work!
Also What are good plugs and wires to get?
I was guessing the stock are probably the best replacement for an un modified car???
HELP PLEASE
thanks
Old Jul 3, 2002 | 02:12 PM
sir_sun's Avatar
I have the same problem with you too.
My car jerks at constant rev, but i can't get to high revs with my car. i still dont' know why. When i press the gas to the floor, it can't get more then 3500K revs, then it lose it power.
I went to the mech. he told me i have to bring my car back to the dealer to get my "throttle body valve" change. i'm not sure if is true, what do you guys think?
Please help.
Old Jul 3, 2002 | 02:15 PM
dre_2ooo's Avatar
The7, Hmmmmmmmmm.... could be a vacuum tube leak. Make sure your whole intake system is airtight .
Could be the TPS too.
Does your exhaust smell a tad like gasoline?
Old Jul 3, 2002 | 02:20 PM
Taranis's Avatar
Sounds to me like a TPS, 7. Have you adjusted it and how? Personally, I like a digital VM. Look up instructions on the net if you need to. Easy as **** and works beautifully.
sir sun, the jerking at say, @2500 RPM most likely is the TPS. The 3500rpm thing sounds like your secondary injectors aren't coming online. Had a compression test done lately? DON'T GO TO A DEALERSHIP! Take it to a reputable rotary mechanic.. that "throttle body valve" might be what we'd call the BAC, but who knows... still sounds fishy to me. Get a 2nd opinion.
JB
Old Jul 3, 2002 | 02:46 PM
dmyers's Avatar
A vacuum tube you say? Is he driving a Magnavox?
Old Jul 3, 2002 | 03:07 PM
The 7's Avatar
It does smell a little like gas?????
more than a normal exhast i mean.
Never adjusted the TPS
Old Jul 3, 2002 | 03:24 PM
dmyers's Avatar
I have a similar problem, smelling gas, poor idle, misfiring at high rpm, etc. My problem was diagnosed as a bad throttle body that was not opening and closing as it shoud as well as bad catalytic converter. BTW I did take it to a rotary guru after growing weary of watching the local dealership hump the football. I ordered a used TB off of EBay (as well as entire upper intake) for $90.
Old Jul 3, 2002 | 04:01 PM
The 7's Avatar
Right on man Thanks a lot
Old Jul 3, 2002 | 04:03 PM
dre_2ooo's Avatar
Yeah, the TB's on these car can cause serious problems is not adjusted almost perfectly....
Old Jul 3, 2002 | 04:07 PM
The 7's Avatar
Thats just what i need to hear
The 7's Avatar
Do i need any TOOLs or meters to adjust my TPS?????????????????????????
Old Jul 3, 2002 | 04:08 PM
jimmyv13's Avatar
Round&Round not Up&Down
Originally posted by dmyers
hump the football
Great quote from Days of Thunder........
"we look like a bunch of monkeys trying to **** a football out there!!!!"
Old Jul 3, 2002 | 06:00 PM
The 7's Avatar
c
DerpyToast
14
Nov 23, 2024 05:19 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
