fuel systems
Old Dec 16, 2010 | 05:39 PM
stevensimon's Avatar
fuel systems
hello guys.
i am curious with a few things about fuel
first i am going to be running 550cc primaries and 1600cc bosh whites
i am going to be running a bosch 044 pump in the stock fc tank
i guess this is up for open discussion but my direct question is; what do i need as far as a fuel pressure regulator? can someone with experience reccomend a good regulator? i am assuming that i will need a raising rate regulator but i have never done anything with fuel beyond putting in 680cc secondaries and a walboro 255 pump in my stock turbo2 car.
other maybe useful info. b code 20b with stock ports, t72 turbo, 400hp at low boost is what i expect to make with this setup.
thanks for the hints, tips and help
Old Dec 16, 2010 | 08:50 PM
t-von's Avatar
Rotor Head Extreme
This is what I'm using!
http://www.summitracing.com/parts/AEI-13109/
Old Dec 16, 2010 | 11:46 PM
Jeff20B's Avatar
Lapping = Fapping
stevensimon, could you do dual walbro 255 pumps? I mean you already have one.
Come to think of it, maybe one Bosch 044 would be best for you as yours mounts in-tank. Mine is external so I can do dual walbros I suppose.
Do they make an external 044?
Old Dec 17, 2010 | 09:48 AM
ive seen cradles for dual 044's so im sure you can mount them externally if you liked.
Old Dec 17, 2010 | 10:26 AM
ok so i ordered
3x bosch 1600 whites
bosch 044 pump
aeromotive 13109 fpr
aeromotive liquid filled fuel pressure gauge
does this mean that i have to use an fittings now?
Old Dec 17, 2010 | 10:37 AM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
http://www.jayracing.com/index.php?m...=index&cPath=2
They have AN fittings that fit the Bosch 044.
Old Dec 17, 2010 | 04:24 PM
thanks.
Old Dec 19, 2010 | 07:45 PM
salva's Avatar
Rotary Restorer
What about the fuel rail? which one did you use for the 1600's?
Old Dec 19, 2010 | 08:06 PM
Blackadde///'s Avatar
20b GTX4294R MS Dry-Sump
Also curious if anyone offers aftermarket fuel rails? Running 4x2000cc ID & 2x1000cc ID's...(E85)
Old Dec 20, 2010 | 10:55 AM
patman's Avatar
Resident Know-it-All
I just welded AN fittings to the stock 20B rails. I dont think anyone makes direct fit 20B aftermarket ones, but you can get fuel rail extrusion from KG or Summit.... As for regulator that setup should be fine. Make sure to use large enough lines to take the flow.
I run dual walbros in the tank and it works fine for 600whp. I also highly recommend a in cabin fuel pressure gauge so that if you ever have pump issues you will know before you hurt anything.
Old Dec 20, 2010 | 04:08 PM
the guy that i ordered my injectors from, actually turned them down so they will fit in the stock rail with no further mods.
Old Feb 3, 2011 | 12:51 AM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
D-
Not sure if its after the fact now, but KG Parts has both primary and secondary aftermarket fuel rails.
I sent my LIM to KG Parts, so he could measure and make me some secondary rails and brackets, and I think he just got measurements for the primaries from a local stock block.
EDIT: I can't find them on his site, maybe call if your interested.
Old Feb 3, 2011 | 04:54 AM
Banzai-Racing's Avatar
Rotary Specialists
20B Fuel rails http://banzai-racing.com/store/20b_Fuel_Rails.html
Old Feb 3, 2011 | 08:44 AM
to_slow's Avatar
-8 custom rail for your 20b from chipmotorsports...
He did mine... if you wana run e85 you need to run -8 or larger fuel rails...
Snook
21
Sep 1, 2015 06:32 PM
82streetracer
Aug 23, 2015 09:28 AM
