smaller replacement battery
Old Jul 3, 2002 | 03:28 AM
rxshun7's Avatar
I noticed that a few people on the forum are using a smaller battery with their front mount intercooler setups rather than relocating to the interior or trunk of their car. I wanted to know what kind of battery people use in the stock location instead of relocating the stock sized battery somewhere else. I've seen it referred to as an "odyssey" battery, but I haven't been able to locate anything related to that brand or application. If anyone can help I would appreciate it. Also, does the smaller battery setup require modification of the factory battery tray?
Old Jul 3, 2002 | 08:55 AM
Jonesboro's Avatar
Hawker Odyssey PC680, $86 from this source:
http://www.batterymart.com/merchant2...y_Code=odyssey
Old Jul 3, 2002 | 09:03 AM
ttpowerd's Avatar
HARRRRRRRRR
Thanks for the link, I am in the middle of relocating mine.
Old Jul 3, 2002 | 10:07 AM
DavidDeco's Avatar
I have more fun than you.
I got the Hawker for $69.95. Supposedly the Odessey PC680 is the same battery resold under their label. At least that's what some thread I read from a writeup on some board (lost the link).
It's like 13 lbs. I ordered mine from Portable Power Systems, Inc. at www.GotBatteries.com.
I actually relocated mine to the passenger compartment though. Fits great in there being so small.
Old Jul 3, 2002 | 11:52 AM
Jonesboro's Avatar
DavidDeco,
It appears to me that you got that Hawker Genesis for $69.95, a lead-acid battery, not the Odyssey which is a dry-cell battery, completely different technology.
Old Jul 3, 2002 | 12:09 PM
rxshun7's Avatar
Do you have to modify the stock battery tray with the odyssey? Thanks.
Old Jul 3, 2002 | 12:24 PM
Jonesboro's Avatar
The Odyssey is much smaller than the stock battery, so it will not fit appropriately in the stock tray. But, that's one of the big advantages of going with the Odyssey, to free-up room where the stock battery is located. Now's the time to consider moving the battery to the inside of the vehicle.
It is easy to take some sheet metal and make a new battery tray, no big deal.
Old Jul 3, 2002 | 01:33 PM
Blackbeast's Avatar
Battery Relocating
Where do you guys feed the power wires through the FD firewall?
Timmy
Old Jul 3, 2002 | 01:40 PM
DK's Avatar
DK
40k worth of fail
Re: Battery Relocating
Timmy
ECU harness hole. It's plenty big enough for anything that you want to go through there.
Old Jul 3, 2002 | 01:52 PM
Jonesboro's Avatar
This link goes to a thread that discusses running the wire when relocating the battery to the interior:
https://www.rx7club.com/forum/showth...and+relocation
This link goes to a picture of the Odyssey in a rear bin:
https://www.rx7club.com/forum/attach...&postid=300905
Old Jul 3, 2002 | 04:25 PM
turbojeff's Avatar
Do it right, do it once
SS battery trays for Medium sized ICs
It uses a 51R battery that is about 10lbs lighter and 2" narrower than stock. It is a direct bolt-in, no cutting or mods required other than a new battery.
I designed this tray to prevent the stock battery from rubbing on M2 med or PFS sized ICs. I have rear seats in my FD so I couldn't put a battery in the rear bin and the 51R battery (common to some Hondas) has more capacity than the smaller dry cell or gel cell batteries. If you don't have an aftermarket IC this tray will still help your car loose 10lbs and leave more room for air to exit the radiator.
This is the last batch I'm selling, about 50 of them have already been sold, never a complaint about the fit, the trays lines up with the stock mounting points perfectly. It uses the stock J-bolts along with a custom cross piece for tie downs.
email me if your interested, cost is $55+$5 shipping. Pics at:
http://www.wvinter.net/~flanham/wlanham/battery
Thanks,
Jeff
Above is a cut and paste from about 1yr ago...
Jeff
Old Jul 3, 2002 | 08:46 PM
DavidDeco's Avatar
Originally posted by Jonesboro
DavidDeco,
Nope, it's Dry Cell.
Old Jul 3, 2002 | 09:02 PM
Jonesboro's Avatar
DavidDeco,
If this is the PC680 then what is the item number you used to purchase the battery and/or the direct link to the web site to obtain it at the $69 price.
Old Jul 3, 2002 | 09:12 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
I have a 51r battery that I bought from sears that is 10 lbs lighter than the stock battery.
Old Jul 4, 2002 | 01:53 AM
ptrhahn's Avatar
I use the PC925. A little bigger and more powerful than the 680... no drain issues or anything. Not quite small enough to leave under the hood w/ an M2 large IC, but does allow extra flow from the rad. Would also fit nicely in a bin without cutting.
Old Jul 10, 2002 | 10:18 PM
DavidDeco's Avatar
DavidDeco,
I screwed up on the price. I was looking at multiple ones and for some reason the $69 stuck in my head.
Old Jul 11, 2002 | 11:34 AM
NewbernD's Avatar
Tequila? ..it's like beer
I've got the PC925 also.. from batteryweb.com. Turned on its side, it's not much larger than the 680... and I happen to have a spare battery tray for it (before I went front mount). If that'd help anyone out, you can have it.
Oh, and I'd recommend paying the extra $10 and getting the steel jacket on the battery.. it raises the max operating temperature rating a bit.
Dave
Old Jul 11, 2002 | 12:53 PM
95R2-89TII Ground Zero's Avatar
Banned
Just relocate the battery to the rear passanger compartment. That would be easier, and it's better for weight distribution.
Old Jul 11, 2002 | 02:09 PM
martini's Avatar
http://www.bakerprecision.com/battery.htm
Old Jul 11, 2002 | 02:37 PM
Silex's Avatar
Okay martini, I'll bite. What about them Baker's?
Old Jul 11, 2002 | 05:54 PM
martini's Avatar
though slightly bigger, it has more CCA, and more Ah, is gel filled, and like the Odessey, is completely sealed.
Similar price too..
Mysel, I just went out and bought an Optima Red Top. I haven't been let down yet (except my battery tie down doesn't fit very well anymore).
Old Jul 14, 2002 | 11:35 AM
rx4ur7's Avatar
has anybody tried a miata battery from the dalership,i actually have a relocation kit that i do and as part of that kit the miata battery is included, this is one of the smallest batteries on the market and most dealers keep them in stock
Old Jul 19, 2002 | 03:22 PM
SanJoRX7's Avatar
uid 0
How much is that Miata battery? If it's lead-acid though, some folks might not want it. If i opt to relo the battery to the passenger compartment, I'm DEFINITELY not getting anything other than dry cell just for my own safety.
Patrick
streetlegal?
Mar 17, 2022 02:46 PM
rotor_veux
Aug 31, 2015 07:49 PM
RCCAZ 1
Aug 11, 2015 07:05 PM
