N2O 4 my 13BT 87' FC3S in 2002...
Old Jul 1, 2002 | 08:56 PM
boostmotorsport's Avatar
Hows that thread title for ya!?
So tonight I am acquiring a NX wet kit to install in my T2. My relevant mods are as follows
Intake and tid mod
3" turbo back
ported TB
starion fmic
elec fan
stock ser 4 turbo with well ported wg
home dpot boost controller
walbro rewired pump
safc
800 secondaries
fcd
egt,boost,and af guages
to run a 50 shot I plan on button activating it for 3rd and 4th gears, and checking the following
12 volts at fuel pump
octane at 94 or better
richer than normal fuel maps on safc
turn boost down to around 9 lbs(before spraying)
Did I miss anything? input?
Old Jul 1, 2002 | 10:17 PM
fc3s.org's Avatar
OG
With a wet system, you should have plenty of fuel to compensate the N20. Is it a jet system, or computer controlled one? I am only familiar with the NOS brand systems. With the correct jets in the NOS brand system, I didn't have to change a thing with the rest of the car.
Old Jul 1, 2002 | 10:49 PM
It is a jet system. I have seen on your sight the install on an NA, aver juiced a turbo model? Thanx for the reply.
Old Jul 1, 2002 | 11:10 PM
fc3s.org's Avatar
OG
Nope, not on a turbo, but the results are similar. You would get alot of the lag removed if you used it lower in the RPM range.
Old Jul 1, 2002 | 11:15 PM
Tec's Avatar
Tec
It's going to be bad ***!! I have my old dry system hooked up as a I\C sprayer! We all know how bad the stock top mount sucks! I have all the parts to convert to a wet system.......but my TII has 143k on the clock and dyno'd @ 187 WRHP @ 5 psi!! I would still like to drive it before winter! N2O next summer after rebuild
Old Jul 2, 2002 | 12:53 AM
RexRyder's Avatar
Thumbs down
anyone heard of N2O cooling your IC? I was reading in a mag that it could get you 50+ horses? Then again you could just pour some FREON on your IC for MAX results
Old Jul 2, 2002 | 01:41 AM
AreExSeven's Avatar
Huh?
I was unaware that an intercooler added HP?
Old Jul 2, 2002 | 01:50 AM
E6KT2's Avatar
Boostmotorsport, did you get my PM about the door panels? (sorry, the forum PM function is "iffy" lately)
Old Jul 2, 2002 | 07:40 AM
BlackFC's Avatar
Be careful with the boost. I did quite a bit of research on spraying turbocharged engines when I had my DSM. Turn the boost WAY down at first bit keep the fuel tuned in, a DSM with a 16g with a ported enlarged wastegate can see a boost increase of almost 10psi INSTANTLY when you hit the blow. This is a 34mm flapper wich i think is bigger than the S4 wastegate can get. On an external and 20g I was still looking at backing off the boost atleast 5psi to keep it safe for the big spike when it was on the bottle. The stock WG is very small and inadequate, just becarful and watch the boost.
Old Jul 2, 2002 | 09:22 AM
Damn thats a big boost spike!! Anyone else have any experience with anything of that nature!?
Old Jul 2, 2002 | 09:55 AM
Megaspeed7's Avatar
Exclamation hehe no but I saw it on a Drag only T66 powered honda!
I saw a honda drag car on some monster slicks hit the spray in 2nd gear and you shoulda heard that friggin turbo spool up then start smoking the slicks for all of 2nd gear! He ran a 10.5 at some ridiculous mph and me and my bro both were wiggin when we saw it! Maybe I will leave the .96 A/R on my 60-1 and run the juice to spool....hmmm.....
Patrick
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
BLUE TII
Sep 26, 2015 10:12 PM
befarrer
Sep 22, 2015 09:33 AM
