Power FC Whats wrong with this map..
Old Nov 11, 2010 | 08:37 PM
SSDTURBO2's Avatar
This map was provided for me by banzai when i got their adapter.. It has been giving me flooding issues. If anyone can look at the map and give a few suggestions or if u have similar mods to me and have a map that would work too these are my mods:
S4t2
intake
exhaust
stock turbo
street port
stock tmic
550pri,1600sec
walbro fuel pump
plx wideband
dataloggit
thats all i can think of right now..
If anyone could help that would be great..
File Type: zip
Old Nov 11, 2010 | 09:20 PM
Banzai-Racing's Avatar
Rotary Specialists
Nothing is "wrong" with the base map. If you are flooding, then find the rich spots and fix them. It is a base map, you need to tune it to your car's specific characteristics.
Old Nov 11, 2010 | 09:32 PM
blue87's Avatar
Hello can you explain what you mean by flooding issues? After you shut off the car you have trouble restarting? does it happen when the engine is cold and has been sitting, or when it is restarted while still warm? Do you know what your AFRs are just after crank, do you have a log of your cranking AFRs? Once the engine is warm and running is it OK? does this happen every time or just sometimes? Are you sure it isn't the injectors/fuel system... I know even stock the 2nd gens have a lot of flooding issues...
do you have an aftermarket fuel pressure regulator, or are you running stock fuel pressure?
Old Nov 11, 2010 | 09:52 PM
SSDTURBO2's Avatar
the issue would be that its flooding while trying to crank it on.. i "de-flood" the motor by taking out the spark plugs and turning the motor with the fuelpump off.. i dont have the wideband hooked up to the PFC so i couldnt give u any logs for the AFRs but the wideband doesnt move from the rich position( gauge is telling me rch) i also changed out the injectors for some other 550and they seem to be fine..
i just have a stock fuel pressure
Old Nov 11, 2010 | 11:32 PM
blue87's Avatar
Once you get it started does it run ok or does it die? If so you need to change the crank fuel. Otherwise you need to change the fuel map.
Old Nov 11, 2010 | 11:40 PM
arghx's Avatar
rotorhead
Both the cranking fuel table and water temp correction table in that map are actually supplying less fuel than what Apex'i sets as a default. And even the factory defaults aren't known for flooding really, especially compared to the factory FC computers which do tend to have flooding problems. There may be something mechanical at work.
Old Nov 12, 2010 | 06:27 AM
Rotary Specialists
Lets get a few basics out of the way.
You have an S4, is it 87 or 88? Resistor pack or not? If not, are the 550's High or Low impedence and do you have resistors wired in?
Look at the 1600's make sure they are functioning properly. Change them out temporarily for your spare 550's, to verify that one or both are not stuck open.
Let's also verify that you have the 1600's in the secondary rail (longer one on the LIM), there seems to be a lot of confusion about the primary and secondary rails on this forum recently.
Old Nov 12, 2010 | 08:53 AM
SSDTURBO2's Avatar
If i do get the car started it dies out.. But recently i havent got it start..
I have a 87 s4 and i think the injectors are low impedence. Yes the 1600s are on the sec.
I didnt have a problem starting a few weeks ago and i did not change anything on the car
Old Nov 12, 2010 | 10:00 AM
Rotary Specialists
If you never had a problem, then why would you assume there is something wrong with the map? Obviously something has changed, the one thing that hasn't is the map.
Ohm out your injectors. Do you have resistors? Or a resistor pack?
Check your compression.
Old Nov 12, 2010 | 10:09 AM
SSDTURBO2's Avatar
Well when i first turned on my car with the map it idled at 2k and everything out the exhaust was nothing but gas u can pretty much smell it..
Im not sure that if i have those.. the stock computer that i have is the n332
Old Nov 12, 2010 | 11:21 AM
cewrx7r1's Avatar
Eye In The Sky
The map is OK, but:
for any engine, remove the Settings 4 cold timing retard in the IGN vs WaterT Cool table. Its only purpose was to help heat up the cats.
Old Nov 12, 2010 | 11:54 AM
Rotary Specialists
How can anyone help you if you can not provide basic information?
Chang your spark plugs. Then look for vacuum leaks. Where do you have the MAP sensor connected? If you do not have any vacuum at the location, the ECU will be at row 10 on everything, dumping in tons of fuel.
Old Nov 13, 2010 | 06:20 PM
SSDTURBO2's Avatar
I have the map sensor where the stock one would be at.. Is it too far from the manifold?
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
