2 INCH piping
Old Jul 1, 2002 | 04:56 PM
seventhgear's Avatar
boost on the way(GTU II)
Question 2 INCH piping
well i could only get my hands on 2in. piping for my single exhaust i am making but seeing i couldnt get my original idea of 2.5 in. piping for a single i am going to go the dual route? 2in. stainless steel piping what do u think this will do for my engine? i have an apc filter and a pacesetter header which i dont like right now but all in all thatz about it and i will have it going to 2 dynomax turbo mufflers i think its turbo im not sure well thanks ahead of time for the insight
jack
Old Jul 1, 2002 | 05:04 PM
OHH JUS TO PUT IN MY CAR is an 87 sport model
Old Jul 1, 2002 | 08:37 PM
FPrep2ndGenRX7's Avatar
I wouldn't use the turbo mufflers. They probably will not last to long. Borla makes some good mufflers that are stainless outside with stainless steelwool packing. As long as you run true duals you should be ok but if the exhaust is collected into a single pipe that will be to small for good high rpm power. It will work at lower rpm but you may loose some higher up.
Old Jul 1, 2002 | 09:14 PM
Evil Aviator's Avatar
Rotorhead
http://www.burnsstainless.com
Old Jul 1, 2002 | 11:34 PM
ITS ONLY BECAUSe IM running 2in. that i would lose power ? but i will gain more power than i have now though huh? i am running stock piping which i do not know that diameter of ....
Old Jul 2, 2002 | 01:52 AM
rotarygod's Avatar
Rotors still spinning
Before my '88 n/a became the turbo monster it is now, I tried several different exhaust configurations. Anything was better than the stock setup. I had a true dual exhaust made out of 2" pipe with no presilencers through 2 Dynomax superturbo mufflers. It had the most power of any combo I tried. The lowend torque was crazy. It pulled everywhere in the powerband. I didn't blow up the mufflers but I only had that setup for a few months before I pulled the engine. It was DAMN loud! The major downside was it sounded terrible. The car sounded like a one rotor...or in this case 2 one rotors. No it doesn't sound like an RX-7 anymore. It sounds like a dying motor with no compression. Those of you who have heard it know what I'm talking about. The collected exhaust with a header and the same mufflers sounded awesome but still loud. Power may have been slightly higher at the very top of the RPM range but it was hard to tell since the dual setup had TONS more low/midrange power.
Fred
Old Jul 3, 2002 | 11:01 PM
KOOL WELL I WANT TRU DUAL BUT NOT GONNA HAPPEn soon well im makin 2 in all the way back from header no cats and no airpump .2 dynomax super turbo's what do u think about that ?>
Old Jul 4, 2002 | 11:10 PM
can anyone help me on this one?
Old Jul 5, 2002 | 03:27 AM
BlackRx7's Avatar
Daily Domestic Killer
that would be less restrictive than stock
Old Jul 5, 2002 | 01:26 PM
so would it free up a lil hp ? and by the way how much hp do u think removing the a/p frees up ?
jack
Old Jul 5, 2002 | 05:31 PM
Manolis_D's Avatar
removing the airpump probably frees up <1 HP... ever tried spinning that thing? -- almost no resistance...
Old Jul 7, 2002 | 10:47 AM
LOL hey well maybe itll help me out a lil by removing it and wiring open the ports what do u guys with wired open ports think ? well that my exhaust and a cold air box will be my last mods...
then interior here i come!!!!!
Old Jul 12, 2002 | 12:17 AM
hey guys does ne one have n e input on my setup ? i would love to hear n e ones 2 cents thanks again
jack
Old Jul 12, 2002 | 12:21 AM
Felix Wankel's Avatar
Super Newbie
True duals wouldn't happen in the first place anyhow, since that header is collected. Running a single 2'' back to a Y pipe might give a little power, but mostly just from losing the converters. I don't think 2'' is much bigger than stock.
Old Jul 12, 2002 | 12:55 AM
Ryde _Or_Die's Avatar
How come you couldn't get any 2.5" piping?
Old Jul 16, 2002 | 01:25 AM
rotarygod's Avatar
I had the aux ports disabled on my car. I pulled the sleeves out and put an epoxy radius in them so the air would flow better. The actuator rods were also removed from the manifold. There was a loss of lowend torque (we have so little to begin with) but the improvement on the topend was noticable. This is only because of the radius in the sleeves. The sleeves had to be epoxied in since the engine will just turn them shut and leave them there. Removing the control rods also permits much more flow through the top ports. If you have the manifold off look at the size of the port runners and then look at the size of the actuator rods. Big improvement by taking them out. I had no air pump, and 550 cc secondary injectors from a T-II with a 3rd gen fuel pump. Fantastic top end. With no internal engine work it ran right with my friends stock '89 T-II. I still have the header, leftover 2" piping, and a spare 3rd gen fuel pump if you want any of them. I even have 2 of the superturbo mufflers brand new (not the ones on the car) in the boxes if you have a need for any of them. A single 2" pipe is way too restrictive. It will be very noticable when you upgrade.
Fred
vy_MR2
Sep 16, 2015 06:39 AM
yetter227
20
Sep 5, 2015 11:57 PM
