MoTeC Area is for discussing the MoTeC EMS.
MoTeC *NEW* Motec M84
Old Nov 5, 2010 | 04:36 PM
Nige's Avatar
Ignition Autosport
*NEW* Motec M84
http://www.motec.com.au/m84/m84overview/
It is basically cut down M800 hardware with fixed outputs, logging and single onboard lambda enabled, a single EGT input (requires external amp) etc.
I think it would be idea for a LOT of 2 rotors, being that you can have dual Lambda (second Lambda is an enable option) and dual EGT (second EGT on the single User definable AV).
It has been released to fill the void that will be left at that end of their product line when the M1 ones out.
Just a heads up, something to check out.
Old Nov 8, 2010 | 06:30 PM
2a+RoN's Avatar
Yeah, can't wait for these and priced at $2550 MSRP they're a steal for their capabilities..
*Note, it will support 3 or even 4 rotors...*
Old Nov 9, 2010 | 05:21 AM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
WOW.. for someone already in EFI purgatory, now I have another temptation!
Aaron, I assume the price you mentioned is without harness?
Old Nov 9, 2010 | 09:33 AM
2a+RoN's Avatar
It is without the harness. However, I also noticed that John Reed Racing listed the upgrade options as much cheaper for this ECU as well (Motec US hasn't updated their catalog yet). I am anxiously awaiting the software release so I can see what differences it will have with version 3.
Old Nov 9, 2010 | 09:48 AM
2a+RoN's Avatar
Well looks like they just put up the software yesterday! Good news, we got 3D battery comp tables in it, hello fully linearized fuel injectors!!!
Old Nov 18, 2010 | 02:57 PM
Nige's Avatar
Ignition Autosport
Note that it has locked table axis, only scale can be changed.
Also CAN channels are locked, so those looking to use it as part of a larger setup (with ADL3/PDM etc) may be limited to a degree. Check first.
Old Dec 1, 2010 | 02:37 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
I am planning on using this new ECU in my race car as I move to a 20b. I moved to the motec PDU last season and love it.
I will be posting a full build thread on the 20b move and it will include ECU notes as they come up.
Old Dec 1, 2010 | 05:33 AM
Veteran: Navy
Top Answer: 1
Right on Damian!! I'll look forward to your updates since I'm very much interested in the real-world application of this model.
Old Dec 1, 2010 | 09:23 AM
2a+RoN's Avatar
Good to hear! let me know if you have any questions.
Old Jan 12, 2011 | 05:33 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
oh I have a LOT of questions :-)
have you set one up already? (for a 20b?)
Old Mar 15, 2011 | 12:36 AM
Prometheus's Avatar
Still got it.
Must start group buy...
Old Mar 15, 2011 | 05:17 AM
Veteran: Navy
Top Answer: 1
I suspect the "MOTEC Group Buy" is an oxymorons.
Old Jul 2, 2011 | 04:54 PM
BlowenByTwins's Avatar
I may have to upgrade to this in the near future.
Old Jul 5, 2011 | 02:20 PM
afawaterpolo's Avatar
Slow FD
I'll let you know how it works, should be getting this in 2 weeks.
Old Aug 12, 2011 | 07:24 PM
Slow FD
Got my Motec M84 with all options turned on and wire harness. Getting ready to put it in soon.
Old Sep 8, 2011 | 10:58 PM
BensonMotorSports's Avatar
Some pics below of my FD. It was one of the first RX-7's fitted with an M84 according to the helpful guys at MoTeC R&D in Australia who helped my very committed installer and tuner iron out all the bugs in readiness for the cars first event - Targa Tasmania.
Although running a twin turbo set up at the 2011 event, the car is now going through an upgrade, including the install of a single turbo. The MoTeC setup includes M84 with advanced options, SDL, SLM, GPS, boost controller and a host of sensors.
