Drifting Discuss Drifting and drifting techniques here.
What for?
Old Oct 17, 2010 | 12:58 AM
Linguo415's Avatar
What for?
what's up all. While I'm not new to drift I'm still learning. So my car is all stock except for the kyb agx shocks and some kind of springs I'm not familiar with. The guy I got it from says they are eiboch. I suppose his is good enough to get side ways. I know you don't have to go crazy with mods. Anyway. My actual question is why do people do a Stretch with their tires? Is there a benefit to this? If so would there it be as beneficial to stretch on stock width wheels?
Old Oct 17, 2010 | 01:08 AM
NoPistons!'s Avatar
Tango Down
fitment and looks are a great reason.
Stretching a tire changes the slip angle of the tire and makes the sidewall super stiff. You dont get that nasty deflection and sidewall roll when running lower tire pressures either.
Mostly, it's for looks.
Old Oct 17, 2010 | 02:33 AM
Linguo415's Avatar
I see. Well I am running. enkies that are stock width. Is there a tire width you could recomend for a stretch? Stock tire size is 205 obviously. I was thinking about running a cheapy set of tires in the back that I can break loose more easily since I am still learning. My car has BF Goodridge G force sports 225/50 all around. So I dont want to thrash those just yet.
Old Oct 17, 2010 | 03:57 AM
NoPistons!'s Avatar
Tango Down
well dood, just go to whatever used tire place of your choosing and get matching pairs of whatever.
The trick is to stuff really wide wheels under your arches and balance your tire widths out based on clearance and desired grip. If you're running 6.5 to 7" wide wheels, you really dont need to run stretch. You NEED traction to drift.
You should keep the 225 g forces up front and just run whatever's cheap in the back. LIke some 205 off brand budget tires like goodrides or sunnys or whatever is used and cheap. Tire pressure, technique and a diff is going to effect your breakout more than stretch.
If you want stretch, you've gotta step up on the wheels. Banded steelies, mustang wheels, whatever....just something wider. you NEED traction to drift. Stretching on a 6.5-7" wide rim is going to be like driving on ice. You'll be making smoke and noise but probably not gaining any speed.
Most tire brands that stretch good (when you're ready) are nankang, bct, sunny, nexen, kumho, federal, falken, riken, maxxis...etc...
High end goodyear, michelin and pirelli tires stretch like **** if you can even get them to because they are expensive as **** and designed to have super stiff sidewalls that resist roll and deflection. I would stay away from these unless you want to run close to full recommended width on your wheels.
I hear mixed things about dunlops. Some like to stretch, others dont.
Old Oct 17, 2010 | 05:21 PM
Linguo415's Avatar
Thanks for the tire info. Good advice on the rear tires. Thats what I was thinking about doing. Maybe some sumitomos or something. Ive heard they last a long time.
Old Oct 17, 2010 | 07:23 PM
NoPistons!'s Avatar
Tango Down
Yeah. Sumi's, wanli's whatever you can get your hands on.
Old Oct 19, 2010 | 10:34 PM
Skidtron's Avatar
Being poor sucks!
They do it for looks mostly. To add to what was already said. You can drift on any tire if you are familiar with the car. At least i can. I am running factory size on T2 heavy *** junk rims and have no problems. I haven't changed sizes due to the lack of steering in the front. Once the knuckles get modded then its a whole new ball game.
Old Oct 20, 2010 | 02:55 AM
Linguo415's Avatar
What kind of mod are you doing to the knuckles?
Old Oct 21, 2010 | 01:49 AM
NoPistons!'s Avatar
Tango Down
You modify your steering geometry by moving the tie rod pickup point closer to the hub.
Less turns lock to lock (right?) and more available steering angle. I wouldn't worry about that just yet but it's worth looking into further if you plan on doing this drift thing for a bit and it's not just a fad or trend for you.
Old Oct 21, 2010 | 01:11 PM
Linguo415's Avatar
Naw man. ive been wanting to do this since I saw my first option vhs back in 1999. I just have to fix my engine.
Old Oct 26, 2010 | 12:45 PM
Linguo415's Avatar
Is there a benefit to having larger diamiter rims when it comes to drift on stock power? 18 look nice but what else?
Old Oct 26, 2010 | 02:59 PM
Linguo415's Avatar
Is there more control with the bigger Rim versus the smaller rim while mid drift or something? What differences besided size is there between a stock 16" and 17x9.5 or 18x9.5? Any?
Old Oct 27, 2010 | 09:13 PM
FC_fan's Avatar
Sideways is the only way
well, bigger rim size means a lower profile tire. that increases the contact patch and makes the tire flatter to the road. I would assume you would have more traction and it would be harder to break loose. but I'm in the same boat as you and don't really know the specifics. I don't think you need them on stock power unless you just want better looking wheels.
Old Oct 28, 2010 | 12:05 AM
Linguo415's Avatar
Well i would think it is harder to break loose if the tires match the rim width. But then again you can use not so grippy tires on a stretch like the fellas above are saying. And once you pull the hand break at an angle the tire has broken loose right? ONce its loose its loose but i wonder about keeping it going around the corner. Im sure its harder on the engine trying to turn a bigger wheel. I know youre speed changes and wont match the speedo on 18" at normal highway rpm. You actually end up going faster that the speedo reads out. Not sure by how much. Cant be that much more though. Looks are important arent they? lol
Old Oct 28, 2010 | 01:24 AM
Zenki FC3S's Avatar
\\TRASHTALK//
Old Oct 28, 2010 | 02:00 AM
Linguo415's Avatar
Originally Posted by Zenki FC3S
Thats almost 90 degees! Thats awesome! How much did that run you if you dont mind my asking? What kind of coil overs are those?
Old Oct 28, 2010 | 04:12 AM
Zenki FC3S's Avatar
\\TRASHTALK//
i cut them myself... and a friend TIG welded them for like $20. LEGIT!!!!
muthafuckin Ksport coilovers foo
Old Oct 28, 2010 | 01:52 PM
Linguo415's Avatar
Drifter on a budget! Thats what im talking about. Sick! What did you cut on the knuckle? How do you like the Ksport. Im assuming its specific for drift. Is the highth adjustable? Your car looks like its pretty low.
Old Oct 28, 2010 | 02:36 PM
NoPistons!'s Avatar
Tango Down
You've got some googling to do. For real.
Yes, the height is adjustable.
You cut a section out of the knuckle between the knuckle body and the tie rod pick up point. You're modifying the length of one lever while keeping another the same length so you get more action for less work.
Asking how all that comes together and how it effects things either requires you to not give a **** about specifics, go out and drive or extensive reading up on suspension geometry. It's alot of math, headache and bullshit but worth learning about if you have the time to do so.
Old Oct 28, 2010 | 02:56 PM
stevensimon's Avatar
how did you keep your wheel from hitting the frame and wheel well?
Old Oct 28, 2010 | 02:57 PM
Linguo415's Avatar
way ahead of you on the google. Lol
Old Oct 29, 2010 | 02:18 AM
Zenki FC3S's Avatar
\\TRASHTALK//
with a -27 offset and neg camber plus the right ride height. will tub later to go lower
Old Oct 29, 2010 | 06:29 AM
driftfcbuckey's Avatar
RX7-Factory
negative offsets are the way.
i hate my plus19 gay **** rubbing everything with minimal lock
Old Oct 29, 2010 | 10:30 AM
davedge's Avatar
This thread is like 2004 drifting.com.
Old Oct 29, 2010 | 12:07 PM
Zenki FC3S's Avatar
\\TRASHTALK//
ha for old ***** like you...
I didnt even know what an fc was at 15.
