20B stock oil dipstick lenght
Old Oct 13, 2010 | 03:27 AM
hIGGI's Avatar
Could someone please post a pics/lenght of stock oil dipstick for 20B?
I have it, but rubber part on it is moving upside/down, changing effective lenght of measure....
thanks!
Old Oct 13, 2010 | 09:00 AM
Banzai-Racing's Avatar
Rotary Specialists
13.25" from the base of the seal that sits outside the tube to the tip. It is the same as the FD, which I use on mine, which has a much shorter handle portion. I just think it looks better.
Old Oct 13, 2010 | 02:19 PM
hIGGI's Avatar
will try to take pic of mine tomorrow with measuring tape just to be sure
Old Oct 13, 2010 | 03:56 PM
Rotary Specialists
20B is the one with the long handle
Old Oct 13, 2010 | 10:10 PM
t-von's Avatar
Rotor Head Extreme
LOL! I had this same issue last year. I too am using the Fd stick.
Old Oct 14, 2010 | 02:29 AM
hIGGI's Avatar
Banzai
nice work, thanks a lot!
Old Sep 9, 2013 | 04:22 PM
Akagis_white_comet's Avatar
Hey...Cut it out!
This is good information, definitely worth adding to the 20B FAQ as one of the 'hidden' details of a conversion. Banzai, could you please add in measurements for where the low and full marks are in relation to the seal's lip that you originally measured from? I would greatly like to see both the FD & 20B's details here.
I just measured my S4NA FC's dipstick, finding it is 14" when measured as Banzai did. The FULL mark is at 12 9/16" while the LOW mark is at 13 1/4" when measured from the seal's upper lip.
Because the FC's dipstick goes further in than the FD's one does, it skews the reading higher than it actually is, giving a false sense of security on a stock 20B pan. Full on the FC one means it is actually low as I found out today upon locating this thread.
This thread and its reasoning also confirms that the FD oil leaks at the pan also affect the 20B as well.
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
sYnth.
Aug 19, 2015 06:27 PM
20B Forum
Aug 18, 2015 02:46 PM
