pulsation damper
Old Jun 30, 2002 | 11:42 AM
Newbie
pulsation damper
Where can i find pics of the pulsation damper
Old Jun 30, 2002 | 12:55 PM
Mahjik's Avatar
Mr. Links
Lightbulb
What kind of pictures? Of the part?
or the part installed in the car?
Old Jun 30, 2002 | 02:00 PM
page F 105 of the shop manuel. if you dont have a manuel email me, i can send you one. what part of georgia you from?
Old Jun 30, 2002 | 02:29 PM
JONSKI's Avatar
5yr member, joined 2001
Mith Mindphrame holding my hand (and doing most of the work) we got that bitch out and back in. While we were at it, I decided to do the turbo simplification and silicone hose job. I suggest you do the same. Here's a pic.
(Facing the passenger side, solenoid rack (rat's nest) is removed)
It's the black, cylinder shaped thing with a metal pipe underneath it.
It's located:
-on the passenger side of the engine
-above the rear rotor
-screwed into the primary injectors holder (being unscrewed w/ 1/4" wrench and hex screw tip)
-right above the rear rotor's MOP (Metering Oil Pump, the thing with the brown hose)
DO NOT BREAK THE BROWN HOSE
Old Jun 30, 2002 | 02:45 PM
Flybye's Avatar
It's never fast enough...
I found it easier to simply remove the fuel rail...
Besides, if you have a high mileage FD, now would be a good time to send all your injectors out to be cleaned.
At 75k miles, my injectors were only flowing at about 90% of their capacity. The cleaning did wonders
ls1swap
Jun 3, 2024 03:25 PM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
Steelwheelz
Sep 15, 2015 03:22 PM
