o2 sensor
Old Aug 25, 2010 | 03:18 PM
AmT_T's Avatar
Make It Happen!
o2 sensor
I have a stock tune on my Tii my narrowband a/f gauge is showing rich with the ignition on, when I turn the engine on it shows rich. It seems to run fine other than this. I also fiddled with the a/f adjustment to see if i was running too rich. my o2 is good as gone right?
Old Aug 25, 2010 | 04:01 PM
arghx's Avatar
rotorhead
read your own sig.
you pulled out the air pump, of course it's reading rich at idle.
Old Aug 25, 2010 | 05:05 PM
AmT_T's Avatar
Make It Happen!
it was fine before...i bought the car the way it is
Old Aug 25, 2010 | 07:13 PM
RotaryRocket88's Avatar
Top Down, Boost Up
A narrowband gauge is essentially just a light show, but for what it's worth, you should be rich at idle if the air pump is gone (just like arghx said).
Old Aug 25, 2010 | 07:29 PM
RotaryEvolution's Avatar
Sharp Claws
never trust a narrowband gauge for a tuning device even if it is just for out of high load situations. your wiring is 20+ years old and the sensor may be just as old.
Old Aug 25, 2010 | 08:08 PM
AmT_T's Avatar
Make It Happen!
Ever since I bought the car It was working fine.. it would sit at lean, climb to rich as i got into boost. and on cruise it would sweep back and forth. now that I re-attatched some vacuum lines that had come off "i dont know when" now it sits at rich at idle and pretty much stays there
Old Aug 25, 2010 | 08:43 PM
Top Down, Boost Up
You can test the 02 sensor output with a voltmeter too. If it's old, just replace it anyway. A new one is about $20.
Old Aug 25, 2010 | 09:47 PM
durtled's Avatar
or buy an aftermarket o2 sensor and look at an emissions removal layout like this 1 eventhought its for a s5 tii <a href="http://s39.photobucket.com/albums/e152/durtled/?action=view&current=s5t2emissions.png" target="_blank"><img src="http://i39.photobucket.com/albums/e152/durtled/s5t2emissions.png" border="0" alt="Photobucket"></a>
Old Aug 26, 2010 | 09:42 AM
AmT_T's Avatar
Make It Happen!
I already have emissions removed. but my car still has some of those "plugged" vacuum liines installed. does that mean all the ones that are supposed to be plugged i can rip out? it doesnt look like it...
Old Aug 26, 2010 | 09:47 AM
durtled's Avatar
i understand this but u said u hooked 1 back up who knows if its for emmisions or not cause u said u didn't do it who knows if they did it right.
Old Aug 26, 2010 | 10:24 AM
AmT_T's Avatar
Make It Happen!
I'll post some pics when I get a chance maybe that will help
Old Aug 26, 2010 | 03:57 PM
DJGeQue's Avatar
Can't stop breaking my rx
Arghx why would not having the air pump hooked up make the car idle rich? Does it pump unmetered air into the car while idling?
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
