crazy rich but steady idle
Old Aug 24, 2010 | 05:48 PM
JABrx7's Avatar
my car is a 1988 T2 it doesn't have any emissions stuff on it it also have the TB mod done to it. a few days ago i start it up and notice that my afr's are around mid 11's and if i rev it up it will stumble and dip into the 10's and even high 9's. when at idle it's pulling between 10-12 vacuum. i looked to see if maybe it was vacuum leak but i didn't find anything.
Old Aug 24, 2010 | 07:18 PM
JABrx7's Avatar
also no matter what i do to the Variable resistor the afr at idle will not change.
Old Aug 27, 2010 | 04:21 PM
DJGeQue's Avatar
Can't stop breaking my rx
My Variable Resistor isn't changing my idle mixture either and its at 11AFR all but 14.5 under load. And just a heads up JABrx7, everyone I have found to have this problem while searching has had no smog equipment. And someone always comes along and say the poster should put it back on. Although I still haven't found out why that is the case. There must be some de-smogged cars running leaner then 11.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
qqqqball
11
Oct 9, 2015 07:06 PM
Monsterbox
Sep 11, 2015 03:29 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
