got a turbo sizing question
Old Jun 27, 2002 | 04:14 PM
RacerXtreme7's Avatar
NASA geek
Arrow got a turbo sizing question
T series TS04 compressor (2.3" inducer, 3.304" exducer), .53 A/R compressor housing, .94 A/R undivided turbine housing, P trim turbine. appropiet undivided manifold, wastegate, IC, fuel, large street port series 5, etc. etc.
Now this is a BIG turbo........BIG compressor and a undivided .94 = lag to me.....My question is what kind of response should be expected from this turbo?
When does it develope boost??
3700 rpm 10 psi, full boost by 4200rpm?
I assume this is primarly for a drag set up rather then a track car, but how laggy will it be? Is it going to be a dog till it develops boost then all of a sudden have a SURGE of HUGE power?
Will it respond better if the .94 turbine housing is replaced with a .84?
What will its most efficient boost pressures be?
I'm asking for a friend who has this turbo option at a GREAT deal, its a street car, hes power hungry. I'd recommend a .94 or .84 DIVIDED turbine housing with O or P trim turbine wheel and a T04e 60-1 or T04b 60-1 compressor wheel for stop light to stop light, auto cross, track / street car.
Give me some input
Thanks, ~Mike........
Old Jun 27, 2002 | 04:26 PM
Greg's Avatar
you sound like you already know what you are doing. I had the identical turbo on my 87T2 unported. Your 3700 rpm 10 psi, full boost by 4200rpm guestimation sounds correct. I on the other hand was using a slightly larger 60mm compressor wheel. My exhaust was a .96 ptrim divided on a non divided manifold. You can always get a smaller exhaust housing if you like. email me if you need turbine housings new. greg@importformance.com
FD7KiD
15
Feb 26, 2021 10:12 PM
dkwasherexd
May 27, 2017 04:51 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
