Boost
Old Jul 31, 2010 | 03:47 PM
GreenMachine's Avatar
Boost
I just bought a 89 turbo and was wondering how i can increase the boost to 8 psi from 5psi?
thanks
Old Aug 1, 2010 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
A boost controller.
Or upgrade the exhaust.
At 8 PSI, you will require an FCD to prevent the ECU cutting fuel at 8.6 PSI.
You are also going to want an aftermarket boost gauge and some way of measuring A/F ratios (wideband is easiest). After around 8 PSI, you will need to start adding fuel.
Old Aug 7, 2010 | 03:48 PM
i have a wideband that shows AF too and bigger injectors and a APEXI power FC if that is the same thing as FCD
Old Aug 8, 2010 | 12:47 PM
Aaron Cake's Avatar
Engine, Not Motor
The PowerFC replaces the stock ECU and thus eliminates fuel cut. It seems like you are in good shape. You can use a boost controller to raise the boost and then tune the car for higher boost.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
