West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Vacuum Pump for Rent?
Old Jul 31, 2010 | 04:05 AM
MaczPayne's Avatar
Mac Attack
Anyone know a good place where I can rent out a vacuum pump to use on my a/c system?
Old Jul 31, 2010 | 08:23 AM
Siraniko's Avatar
RX for fun
Go to HVACR parts house like Johnstone, not autozone or pep-boys and such
Old Jul 31, 2010 | 08:50 AM
MikePhillips's Avatar
If you open the high pressure side, won't it mostly self-evacuate? Not an AC guy, so....
Old Jul 31, 2010 | 01:02 PM
MaczPayne's Avatar
Mac Attack
Thanks Mel, there's a Johnstone in my area, looks like they have top notch equipment!
Old Aug 2, 2010 | 11:14 PM
Siraniko's Avatar
RX for fun
YW, you can try Air Cold Supply also.
Old Aug 3, 2010 | 10:19 AM
Rotary13B1's Avatar
Why don't you just go over Wacky.., and suck it good! You love to slurp!!
har har har!
Old Aug 3, 2010 | 03:20 PM
frijolee's Avatar
the implications matter
Johnson,
I think I have everything you need (including a pretty good stash of R12). Give me a call if you want to stop by.
-Joel
Old Aug 4, 2010 | 03:09 AM
mike_merryguy's Avatar
suck me beautiful
i bought one from a Autozone or Kragen don't remember, it was NOT a A/C pump however a brake bleeder pump, puts PLENTY of vac on an A/C system though, used it on a couple cars...
Just took an old A/C charger (the blue hose that quick connects to the car) and cut off the CAN side, whatever brand doesn't matter, the ID of the hose was the same as the brake vac pump i bought, its a hand pump so it takes some forearm and time but works just the same...
Old Aug 4, 2010 | 03:47 PM
MaczPayne's Avatar
Mac Attack
Called all those places and none of them will rent. I'll be giving you a call Joel.
Old Aug 4, 2010 | 06:04 PM
suck me beautiful
oh the one I have isn't a rental, it was 50 bucks to buy or less...
i belive it was a Brake Bleed kit (vacum style)
Old Aug 4, 2010 | 08:25 PM
Hypertek's Avatar
Slowpoke
I used a aircompresser and used a harborfrieght one.. Nothing spectacular, but gets all the crap out. then bought a cheapo gauge set and filled up with freeze12. If you need it man i could invite you over but i just been busy.
My setup was ice cold til the drier blew up because i topped off too much freeze12.
Old Aug 4, 2010 | 08:28 PM
Siraniko's Avatar
RX for fun
i used to be a commercial HVACR Tech/install but I cant remember who borrowed my vacuum pump for auto lol
Old Aug 4, 2010 | 09:29 PM
MaczPayne's Avatar
Mac Attack
I have one of those venturi ones from harbor freight too. Thing is though, I don't know if they'll pull enough of a vacuum to get all the water out. My a/c lines have been exposed to air for about 5 months, and it has probably rained 4-5 times at least since January.
Austin, did you pull a vacuum on your system after exposing the lines to the atmosphere? How long did you let it run? How cold's your a/c?
Old Aug 4, 2010 | 11:08 PM
Siraniko's Avatar
RX for fun
you have to look at the manifold gauge. you should pull below 0 microns to ensure that it is clean (beside, if you can pull this much, it means no LEAK). i feel evil today so thats all i can say
Old Aug 12, 2010 | 03:51 PM
Hypertek's Avatar
Slowpoke
sorry i havent replied.. i left it on for a few minutes, i cant recall.. then kept the lines closed from atmosphere with the gauge-set valve, then hook up freon bottles and run car.
ZacMan
Sep 19, 2015 09:20 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
