Power FC I need a PFC Map.. Mods: NS, fmic, rad,walbro pump
Old Jul 27, 2010 | 01:43 PM
mattdavispv9's Avatar
I just dropped in my new motor and it is not running right... I think it could be the PFC... Does anyone have a similar setup
MY MODS:
NS turbos
fmic
3" haste rad
walbro pump
3 bar map sensor
Any help is appreciated...
My motor does idle but it idles very rough. It idles from 400-800... When I give it gas, there is a hesitation and It does not rev well... It also is making a clunking noise... Sounds like it's coming from where the trans is mounted to the engine...
Old Jul 27, 2010 | 10:53 PM
$lacker's Avatar
Fix the clunking, then worry about the PFC
Old Jul 29, 2010 | 07:34 PM
cewrx7r1's Avatar
Eye In The Sky
The three bar map sensor is most likely your problem as you propably have not choosen the appropriate set up for it.
Commander: Settngs - PIM Volt
DL: Settings 3 - PIM Scale Offset
Old Jul 29, 2010 | 08:57 PM
R3AL.CH1CK3N's Avatar
Jesse
Veteran: Marine Corp
I have 1 map that should work fine with your setup. I also have a datalogit and laptop. I actually need to stop by anyway and finally pick up my wheels from you..lol.
msilvia
15
Sep 11, 2015 12:13 PM
vmerino
Sep 5, 2015 11:26 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
