camber adjustment rod....install???
Old Jun 26, 2002 | 10:22 AM
JDM13B's Avatar
i just got a camber adjustment rod in the mail for my rear wheels. it looks pretty simple but just one problem...WHERE DOES IT GO? i got my car jacked up right now and either im blind or something cause i dont see where to put the damn thing. anybody know?...please help me out, my cars on jacks. thanx
Old Jun 26, 2002 | 11:55 AM
LT1-10AE's Avatar
I broke it!
It goes right next to the diff. It will be vertical. The OEM one is just a plain rod that's not adjustable.
Old Jun 26, 2002 | 12:46 PM
Scott 89t2's Avatar
SOLD THE RX-7!
driver side of the diff. going straight up. you can't really see the top bolt
Old Jun 27, 2002 | 08:58 PM
JDM13B's Avatar
okay i got it in...are the adjustable rods on each end suppose to screw inwards to adjust negative camber or extract outwards?
Old Jun 27, 2002 | 09:44 PM
Scott 89t2's Avatar
SOLD THE RX-7!
shorter rod will give less neg camber.
Old Jul 2, 2002 | 09:57 AM
JDM13B's Avatar
i dont know why, i cant get it to shorten..when i put the rod on the car i had to extend it all the way just so it would reach enough to bolt on. now that its on the car if i turn one side to shorten the opposite side gets longer & vice versa. is this right???
Old Jul 2, 2002 | 10:37 AM
LT1-10AE's Avatar
I broke it!
Take it out and make sure you have each end threaded in the same amount. Put it back in and bolt it up top and bottom. Turn the camber link itself to adjust it - don't unbolt it to adjust it.
What brand is your camber link?
Old Jul 2, 2002 | 11:30 AM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
It actually depends on which one you have. Some have to be adjusted off the car, some can be adjusted on the car.
Brad
Old Jul 2, 2002 | 11:34 AM
JDM13B's Avatar
i dont know, i got it from mazdamotorsports.com...im going to try again. yesterday i was trying to do that & i just couldnt get the thing to shorten enough. it kept coming off one end whenever the other end got shorter. i'll try again though how u said to do it.
Old Jul 2, 2002 | 11:37 AM
JDM13B's Avatar
mazda motorsports said on there site that this one is adjustable "while on the car"
Old Jul 2, 2002 | 12:14 PM
LT1-10AE's Avatar
I broke it!
That's the one I have. I'd pull it out and make sure each end is threaded close to the same amount, then bolt the upper and lower mounts in place and then turn the aluminum shaft itself to adjust it. Make it shorter to reduce camber (move top of tire away from car) or make it longer to increase camber (move top of tire towards car)
Old Jul 2, 2002 | 12:44 PM
Scott 89t2's Avatar
SOLD THE RX-7!
take it and make it 1/4 inch or so shorter then the the stock one that came off. you need to jack the subframe back up to line it up. don't make it longer to line up.
Old Jul 3, 2002 | 12:26 AM
mr_vaughn's Avatar
Chillin
I got 1 too from Mazdatrix.
Be careful if you have lowered your car already, the diff might touch the sub frame when you acceclerate.
This happens when the sub frame is pulled up too high and the diff touches it.
I also had the front diff mount replaced because that was broken too
This is what happeing to me with about 1 inch drop on 16 inch wheels
i have to run a negative camber or i get this stupid noise.
Old Jul 3, 2002 | 12:34 AM
87GTR's Avatar
take a BFH and dent the sub frame it will give you more adjustment room and stop that banging noise
Old Jul 3, 2002 | 12:35 AM
87GTR's Avatar
you guys got any pics let see it i the car
Old Jul 3, 2002 | 01:04 PM
rx7_ragtop's Avatar
Hey Tony... I saw your car at BDC's the other night... wassup with that?
Brad
Old Jul 3, 2002 | 09:13 PM
87GTR's Avatar
while im overseas its getting some work done to it.
clean up the haltech install / weight reduction / half Bport!!!!
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
LongDuck
Oct 7, 2015 08:12 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
