beep beep
Old Jun 26, 2002 | 12:05 AM
lowrider65's Avatar
beep beep
my 86 gxl wont stop beeping when driving it ill just be driving along and it starts beeping it goes on for like 15 to 20 mins i dont have a clue as to what is wrong with it i just recently put a motor in it and i checked everything under the hood i can think of.
Old Jun 26, 2002 | 12:12 AM
Ryde _Or_Die's Avatar
Have you checked the actual horn button? Like in my old camry, I got mad at my GF while driving and hit the steering wheel. It wouldn't stop beeping either. Luckily I had some tools with and took off the cover and fixed it.
Old Jun 26, 2002 | 12:16 AM
Scott 89t2's Avatar
SOLD THE RX-7!
do you have power steering? normaly a beeping is a power steering error code.
Old Jun 26, 2002 | 12:18 AM
lowrider65's Avatar
its not my horn thats beeping it like a warning beep but i will check my horn button cause it has different wheel on and mybe a wire touching something i dont know
Old Jun 26, 2002 | 12:21 AM
lowrider65's Avatar
yes could too much fuild cause it to beep because when i get on it it stops and a few mins later after i slow down it start agian
Oh my bad, I thought you meant it was your horn. Are there any warning lights on or do your warning lights even work?
Old Jun 26, 2002 | 12:30 AM
lowrider65's Avatar
yeah everything works fine no other lights come on or nothing just the endless beeping
Old Jun 26, 2002 | 03:15 PM
lowrider65's Avatar
Old Jun 26, 2002 | 03:18 PM
wpgrexx's Avatar
does it come from under the steering column, if so it is probably something wrong with ps. maybe disconnect it if u want, i did that but i had to pull a fuse, can't remember which one though
Old Jun 26, 2002 | 03:43 PM
lowrider65's Avatar
yeah its coming from under the dash im going to try to drain some fuild out of it and see if thats it cause i filled it up to much
Old Jun 26, 2002 | 03:46 PM
wpgrexx's Avatar
make sure all the connections are good, and the belts tight enough
Old Jun 27, 2002 | 12:42 AM
winsbig's Avatar
Newbie
Sounds like your low coolant level warning. Add some water or coolant.
Old Jun 27, 2002 | 09:26 PM
lowrider65's Avatar
its not the coolant sensor i already fixed that buzzer
Old Jun 27, 2002 | 10:10 PM
kristopher_d's Avatar
Just start humming incessantly at the same pitch as the beep. In a couple of weeks you wont even notice the car beeping. Seriously though, it could be any number of things. Go through them all one by one.
Old Jun 27, 2002 | 10:51 PM
seventhgear's Avatar
boost on the way(GTU II)
TRY CHECKING UR FUSES MAYBE BLOWN METER FUSE JUS MY .02
Old Jun 28, 2002 | 10:12 AM
awitte's Avatar
This is often an issue with the speedometer cable. Check this thread:
https://www.rx7club.com/forum/showth...threadid=91799
Old Jun 28, 2002 | 10:39 AM
Icemark's Avatar
I can't believe that no one has answered this yet.
The beeping is the error code from the power steering computer.
How many beeps before it pauses and starts over?
Old Jun 28, 2002 | 01:40 PM
lowrider65's Avatar
im not sure how many beeps it does but mybe like 15-20 beeps it gets quiet a little and thens comes back louder
Blastfastrotary
Sep 11, 2015 12:26 AM
M.C. Language
20
Dec 5, 2002 04:25 PM
M.C. Language
May 9, 2002 12:26 PM
JDuncan
May 1, 2002 12:27 AM
TimeFlip
Mar 1, 2002 09:02 PM
