Alignment results: how's this look to you?
Got my wheel alignment today on my 1991 S5 Tii and it was pretty badly needed. When one wheel was straight the other was pointing inwards and after lifting the front of the suspension it was way out of whack. They asked me if I wanted more focus on cornering or straights so I said cornering as this'll never be a drag beast. These are the results.
To be honest I have no idea if the changes are big, or if it should be much better now. At least it drives straight when the steering wheel is straight (just about) and it feels like it wants to go around corners now. They did say the rear does have a bit more negative camber than spec because the suspension is lowering it and can't be adjusted.
Anyone got any thoughts, or is it a case of "if it feels good for you it's good"?
This is a pretty bad alignment. Just about nothing is even, your front camber is awful, and the toe has only been adjusted for a 'green alignment.' You definitely need more camber up front, it needs to be even as it already is, but not in the back, and all of your toe should be 0 or very close to 0, i.e. 0.01.
I'd probably go as high as -2.0 or maybe -2.5 without worrying about eating tires. It's the combination of TOE plus camber that really destroys tires. This is because instead of the tire just rolling along at x angle of camber, it's now being PUSHED along the road at x degree toe. You have to run a lot of camber by itself before you see tire wear.
Trending Topics
hmmm im running 2.8 in the rear...guess the guys at ntb are conservative on the camber because he said 1 degree was going to chew my tires up but my combination or camber an toe in the rear should even it out he said...dunno ill prob run 2 in the front or maybe a little more...
Spirit Rx-7
Mar 14, 2016 12:36 PM
imitek
13
Oct 28, 2015 10:57 AM
erevos
Sep 15, 2015 09:19 AM
