check this out
Old Jun 25, 2002 | 09:54 PM
j9fd3s's Avatar
Community Builder
check this out
http://www04.u-page.so-net.ne.jp/cf6...KAI/index.html
mike
Old Jun 26, 2002 | 04:20 AM
mad20b's Avatar
Looks like fun!!! But wot a waste of the ida!! He coulda just hung it off the front instead of killing it!!
Old Jun 26, 2002 | 05:41 PM
Kurgan's Avatar
Gaijin Racing
Dude, that is freakin cool as hell!
An NA FB with a 20B... my brain is churning...
"Shut up Nick, you're already in too deep with a 20B FC!!!"
Hmmm, build up a 20b in an NA repu or an NA FB/SA?.........
only time will tell....
Old Jun 27, 2002 | 12:57 AM
j9fd3s's Avatar
Community Builder
i was looking for 13bt 1st gens myself....
mike
Old Jun 27, 2002 | 02:04 PM
Kurgan's Avatar
Gaijin Racing
mike
Like this one?
more pics here:
http://z.gmk2.com/pics/rx7/
That's Zach's car, sitting next to my T2... 84 GSL-SE with a S5 T2 engine and tranny, S6 UIM, Haltech...... it'll scoot when we're done
BTW, did you get those TB adapters yet?
Old Jun 27, 2002 | 02:23 PM
wozzoom's Avatar
Exactly what I was thinking! All motor 20B in my FC.
The overall cost should be less than that of a Turbo 20B... No front mount, no custom intercooler piping, no exhaust manifold/turbo to worry about (Custom header is pretty cheap from RB) If you loose the EFI and go carbs, you wouldn't have to worry about Haltech. Only problem would be timing...
I was asking about this a couple weeks ago. Specifically I wanted to know if you could run the 89-91 High compression NA rotors in a 20B?
Old Jun 27, 2002 | 04:31 PM
Kurgan's Avatar
Gaijin Racing
A carb setup is going to cost you quite a bit, if you want webers... you're going to have to buy 2 of the old IDAs... which typically go for over $800 a piece. The haltech is VERY worth it... The engine already comes with big enough injectors for an NA application. The high compression rotors will work in the engine.
You can do this "cheap" if you already have 3 high comp rotors... there is a dissassembled 20B on the partstrader right now for $2000. Get that sucker and port it to your NA heart's content! The only problem is reassembling the 2 piece eccentric shaft, which I believe requires a special Mazda tool.... I know the tool is required for disassembled. Jason sells E6Ks for $1150... there you go. all you need are seals, 3 leading FC coil packs, a header and a bigger radiator.
Old Jun 27, 2002 | 07:04 PM
j9fd3s's Avatar
Community Builder
Originally posted by Kurgan
Like this one?
more pics here:
sexy, sexy. yes i did get those adaptors, the post office took their time on that one. i found a place in japan that has a 20b header.
mike
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
JoesFC
Oct 5, 2015 08:10 AM
Tem120
Sep 7, 2015 09:53 AM
rotor_veux
Sep 3, 2015 07:10 PM
