Replacing all 3 belts on a 89 GXL?
Old Jun 25, 2010 | 01:53 PM
globalx59's Avatar
Riley Bickford
FL Replacing all 3 belts on a 89 GXL?
i need to change all the belts in my car because theyre wicked worn and im not sure on how to get to putting the belts in. can anyone help me? i already have the new apporpriate belts for the car just need a how to. thanks
Old Jun 25, 2010 | 02:11 PM
RotaryRocket88's Avatar
Top Down, Boost Up
There will be 4 belts: Air pump, alternator, P/S & A/C. If using the stock clutch fan, you'll need to undo the four 10mm nuts where the fan attaches to the water pump pulley. Pull the fan off the studs and out from the shroud to give yourself room to work. Remove the P/S and A/C belts first by loosening the 3/4" nuts in the center of the two idler pulleys. Adjust the 10mm tensioner bolts to allow slack in the belts, then take them off. For the alternator and air pump belts, loosen the bolts at the pivot points & the ones on the adjuster brackets.
whinin
Mar 30, 2019 07:53 PM
doritoloco
Sep 8, 2015 07:58 PM
rotor_veux
Aug 31, 2015 07:49 PM
c0rpse
Aug 25, 2015 11:50 PM
