na bolt on turbo kits?
Old Jun 20, 2010 | 05:53 PM
FC-Carson's Avatar
FC3S
are there any direct bolt on kits for an na 13b 6 port or will i have to search around buying every little peace at a time and would would be needed to be done to turbo my 1990 na gtu thank you
carson
Old Jun 20, 2010 | 06:01 PM
89fc3sgtu's Avatar
boosted fc
no they dont make then search arron cake write up search search
and its cheaper and easier to do a turboII swap
Old Jun 20, 2010 | 07:43 PM
rotordad's Avatar
The Big Ugly!
No kits are currently availble for the NA, but you can use the parts from a 4 port kit. There's a few threads on the subject floating around. Try 6 port turbo or NA turbo in your search.
Old Jun 20, 2010 | 08:13 PM
Spirit-RE's Avatar
carson
Bolt on kit: take the intake, throttle body/cable, intercooler, turbo, exhaust mani, downpipe off a stock Turbo II. Just need to run custom oil/water lines.
Old Jun 20, 2010 | 08:18 PM
Spirit-RE's Avatar
Yes.
If you source parts for a good price, you can do Turbo n/a slightly cheaper than a turbo swap, but it will be way more work. But... The higher compression of a n/a will yield better power, with the side effects of coarse being harder to tune and won't last as long as a turbo motor...
Old Jun 20, 2010 | 10:42 PM
NoPistons!'s Avatar
Tango Down
You can also buy those greddy knock off manifolds on ebay.
They work with n/a intakes due to the angled t4 spacer that comes with.
Make your own turbo kit. If you buy a universal t04b kit off ebay, a manifold, some management and fueling and you're good.
*waits for people to say how stupid it is and how chinese turbos suck.....*
Old Jun 22, 2010 | 04:19 PM
killalot13601's Avatar
It is a good affordable way to put mild boost to your car.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
Turblown
Aug 14, 2015 04:48 PM
