Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek so my NA is hitting boost
Old Jun 16, 2010 | 08:44 PM
Chriz88DX's Avatar
i was just wondering about this after i installed a pill between my map sensor and manifold i took a few logs and noticed at full load (100% thorttle) after 6k the map sensor reads .1 PSI
and when this happens the car feels weird my guess is that the ecu does not know what to do with that input form the map
so is this normal?
side note when i put in the "pill" the map readings really smoothed out and the car seems very smooth at light thorttle.
Old Jun 17, 2010 | 12:28 AM
arghx's Avatar
rotorhead
That pressure sensor reading alone doesn't necessarily indicate a problem. You may in fact have a slightly pressurized intake due to the design of the intake manifolds:
Old Jun 17, 2010 | 01:57 AM
bc_fd3s's Avatar
Canadiana... Eh?
Your car is always "boosting." Gravity boosts 100KPA (this is always "0" on a boost gauge) into your engine at sea level. At higher elevations, if you ran an N/A car and had a boost gauge you would see it wouldn't make a full "0" of vaccum.
Anyways... my bet is your MAP sensor is f'd or needs calibration.
Old Jun 17, 2010 | 01:58 AM
bc_fd3s's Avatar
Canadiana... Eh?
Why did you run a pill? There is no reason to need one. A filter or 1 way check valve sure, but why a pill?
Old Jun 17, 2010 | 10:02 AM
arghx's Avatar
rotorhead
there's a pill from the factory on the FC...
Old Jun 17, 2010 | 10:09 AM
turbo2ltr's Avatar
The pill is a good idea to "filter" high frequency pulses out of the boost signal which results in better running.
The MAP sensor is an absolute pressure sender so the zero point will be affected by Barometric pressure. If the Barometric pressure is very low, it will read boost.
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
