FD boost problem
Old Jun 16, 2010 | 08:11 AM
nockenwelle's Avatar
FD boost problem
hi there,
i have a big problem with my fd!
let me explain: the second turbo must kick in at 4000rpm,but it dont....he is coming at 6ooorpm,after that the boost of the second one is very terrible!
so i am shifting and after i have shift,the first turbo dosent work too!?
now i drive the car.....the second turbo dosent run,i dont know why.....after a few kilometers the car get off,the oil pressure fall down,the oil-lamp is shining,the temperature lamp is shining!
and i cant start the car...it was no oil under the car and i can se a mechanic problem!
when i will start the engine its sounds god,not like a engine kill!
i hope you can help me
Old Jun 16, 2010 | 11:38 PM
gracer7-rx7's Avatar
needs more track time
The best advice I can offer you is to go to the 3rd gen FAQ thread here:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
and scroll down to the Turbo section where you will find some good links on troubleshooting turbo problems.
How long have you had the car? What modifications does it have?
Old Jun 17, 2010 | 05:22 PM
thx,the links are great!
but my problem is that i dont know what the problem is....
i dont know whats wrong with the car!
i neep help
new problem
when i start the engine there was a loud whistle....
is the gas pedal put down and the boost is from -0,5 to 0.... is was done.....over 0 it comes again!
the turbo 1 dosent work korrektly,and so the second one does nothing!?!
please help
Last edited by mar3; Dec 12, 2010 at 04:30 PM. Reason: Merged back-to-back posts...
Old Jun 21, 2010 | 08:52 AM
Mahjik's Avatar
Mr. Links
Arrow
Start working through this site:
http://www.autosportracetech.com/RX-...leshooting.htm
Old Jun 26, 2010 | 10:48 AM
dgeesaman's Avatar
Originally Posted by nockenwelle
old problem done....
new problem
please help
If you hear a whistling sound you should first look for boost leaks. You will need to remove each piece of intake piping between the turbocharger and intake elbow for a detailed inspection.
Old Jul 1, 2010 | 12:17 PM
is it possibel to close all holes and blow air in with a kompressor.....and where its whisle...there is the problem!?
or dosent!?
Old Jul 1, 2010 | 12:36 PM
dgeesaman's Avatar
Yes, that can be done. You'll need to plug both ends of the intake piping. But in my experience that's much harder than simply removing a few pieces and inspecting them carefully.
David
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
gabescanlon
Sep 5, 2015 12:09 AM
tiger18
Sep 3, 2015 08:27 PM
