3 inch down pipe
Old Jun 13, 2010 | 09:30 PM
turbolawnmower's Avatar
3 inch down pipe
hi jsut got my jdm rx7 was wondering if i do a 3inch down pipe to catback exhaust if it is bad for the injector seals i heard that it can blow the injector seals plz post back making a drift car and wanna know some ideas and what route i can go for this car as well as boosting up the stock turbo and what no thank you
Old Jun 13, 2010 | 11:59 PM
RotaryRocket88's Avatar
Top Down, Boost Up
What the heck is an injector seal? Don't ever listen to the person that said that again.
Open exhausts can overwhelm stock internal wastegates, which leads to boost creep and potentially blown engines.
Old Jun 14, 2010 | 07:23 PM
so what route do you think i should go?
Old Jun 14, 2010 | 07:49 PM
Top Down, Boost Up
For what? Read through the 2nd gen section to get familiar with common modifications made to TIIs.
Old Jun 15, 2010 | 07:31 PM
what do you think of FCDs?
Old Jun 16, 2010 | 04:48 PM
Top Down, Boost Up
I don't think much of them. They alter the boost signal to the ECU to get around fuel cut, but that also means fuel and timing are negatively affected. Chipped ECUs from pocketlogger.com (Rtek 1.5, 1.7, 1.8, 2.0+) are much better. What are your plans? Do you just want to be able to safely run more boost on the stock turbo?
Old Jun 17, 2010 | 10:34 PM
for now but basically want to bore out the stock turbos waste gate and rebuild it then i can run more boost with out boost creep i dont want more then 300 hp pretty much
vy_MR2
Sep 16, 2015 06:39 AM
yetter227
20
Sep 5, 2015 11:57 PM
