West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
It is well known that Rx7s have rev limiters
Old Jun 13, 2010 | 07:59 AM
wakazz's Avatar
Bay Area Rotary
Here is the Conversation i had with my friend peter just Mainly about Rev limiters but there is also some other good stuff in there...
4:03amPeter
you nto doiung **** without fuel lol
4:05amMe
huh?
4:06amMe
do what without fuel?
4:07amPeter
turbpo hybrid
4:08amMe
ohhhhh
im gonna have a thrid feuel rail
6 injectors
it wont be for a while though
4:09amPeter
and what will controll it?
4:09amMe
all my money is going into school right now
4:09amPeter
that is useless tho i hopeyou know
4:09amMe
a secondary injector controller
4:09amPeter
unlss u got more power
and bigger turbp
nto hybrid
ust get l;arger secondaries
why add more when you dont need it
4:10amMe
because it already have a manifold with the rail on it
4:10amPeter
u dont get it do you
4:10amMe
remember?
4:10amPeter
u can add another injector with a safc neo
lol
4:10amMe
what do u mean?
4:10amPeter
nothin
;lol
4:10amMe
remember my car that wierd rail on it with the fuel pressure on it?
4:11amPeter
nope
i never looked at your car really
remember
4:15amMe
huh i think i would need a standalone if i went with bigger injectors
4:16amPeter
nope
nope
a neo can controll it
4:17amMe
how?
4:17amPeter
how
the same way a stand alone would
it's actually easier
4:18amMe
without a standalone?
4:18amPeter
cause the NEO has a auto tun or base mapping feature
4:18amMe
with an safc?
4:18amPeter
yes
safc controlls injector
duh
lol
like a stand alone
exactly like one
just transforms stock signal into the preset signal
you have asafc
right
installed with stock injectors
then you install bigger ones
and trim the bandwidth of the larger injectors
usually secondaries
4:20amMe
Safc doesnt controll injectors
4:20amPeter
yes it does fool
4:20amMe
safc works by modifying the air flow meter
4:20amPeter
OMG
and it controlls the fuel
that way
whatever lol
same ****
it is controlling the injector bandwidth
by means of flow meter
signal
which controlls the injectors
4:21amMe
right it modifies the afm and the stock ecu will cut the fuel think its open the way it is
4:21amPeter
SUPER AIR FUEL CONTROLLER
hello
lol
whichever way you wanna put it
same ****
it is controlling the injector bandwidth anyways
that what is it for
4:22amMe
the only problem would be the ecu would cap the injectors somwhere around 66% their max
4:22amPeter
it dosent controll the afm signal
ehhhh nm
the stock ecu still will do its same old precentage
4:24amMe
Have ever installed an safc before?
4:25amPeter
yea
i know
use bigge rinjectors
then you trim it
not mac it out
so the ecu dosent real more signal
it reads less
because with larger injectors they do not have to stay open longer
thats why you get bigger secondaries
hello
then trim
instead of richen
because just having the large on with stock parameters its rich
then u can trim instead of richen secondaried
you can keep primary the same
why do i even have to explain this
bro
you cant teach me anything so dont try
lol
whatyever you get it
get a stand alone then
4:27amMe
or have the stock ecu work
run a fully programmable AIC unit..
you dont trick the ecu
4:28amPeter
yea
u can use the neo as that also
somehow lol
4:28amMe
im not going stand alone
4:28amPeter
no u cant i guess
why not
power fc
or a pro V hks
those are sick
lol
all of them arte sick these days
self tuning
ude the hks f con and AIC then
i like that set up
when i used a fcon
it wokred pretty well
full RB
FCD
fcon
adjustable one
set to 8
andintake
**** was oosting 16 psi
lol
overboosting stock turbo
lol
4:31amPeter
i need the ps1000
4:33amMe
16 is pretty high for fcon
4:33amPeter
stock S5 turbo non ported
thats boost spike
it woudl hit 17
if non ported wastegate
it was ******* fast
then after about 1 yr blew the motor overboosting in 4th gear
80 mph it hit 17
and car was not accelerating enough blew a apex seal
high boost and slow acceleration is death for rotary
lol
4:35amMe
maybe u hooked the wastegate up wrong?
4:36amPeter
no
that what happens to good running S5 turbo II
when you put a full RB exhaust
and fcd
in 100% of good running S5
it is called boost creep
if you dont then your car is not running well
or turbo is worn
or it has a ported WG
every single turbo II i been in that is a S5 overboosts
with a fcd
because the stock WG is too small to bleed off the pressure at high rpm
4:37amMe
i think bad tunning would blow it
4:37amPeter
thats is why people port them
17psi
the stock system is leaning out
4:37amMe
not high boost and slow acceleration
4:37amPeter
14-17
it is not tuning
you dont get it
you didnt own or drive enough turbo ii to know yet
you will learn slowly
lol
trust me i been driving and messing with turbo rx7 for 17 yrs
everyone who knows rx7 turbo II well
will tell you no matter what
S5 with full RB exhaust
and FCD is overboosting
if the WG is not ported
and even then it still does a little
not as bad tho
i owned 5 turbo II S5 in my life
the first one
rx7-heaven bought lol
my driveterain is on his widebody vert
all S5
overboost
or boostcreep
no question about it
even racing beat says so
that is why you need a FCD
the stock computer cuts fuel at 9.8 psi i think
without a FCD you are leaning out and pinging
because of boost cut
so with the fcd
it allows boost creep or overboosting and tricks the computer ionto thinking it;s boosting less
when it is actually 14-17 psi at times!
crazy huh
that is blown motor medicine
u need more fuel brop
no matter what you think
u need it now
put a boost gauge on
4:43amPeter
http://www.racingbeat.com/resultset....rtnumber=11571
4:43amMe
having no FCD doesnt lean the engine - it is a fuel cut - your car isnt even going to spark when you are at 28:1 AFR
it will just mis-fire, not run lean and knock
4:44amPeter
argh
when it cuts fuel
you get a second of lean mixture
4:44amMe
and i do have a fuel computer
4:44amPeter
that can blow the motor trust me
i seen it happen
on my own car
white 90 turbo II
S5 all stock
just
full RB exhaust
FCD
airfilter
blown motor in 7 months
lol
planned to see how long it would take
i probably copuld have dont it faster
but it was hella fast during that whole time
see
the fuel is he same
at higher boost
with a FCD
stock is like 9 lets just say
9 psi
but now your boosting 13-15 and getting the fuel for only 9 psi
its ok for now
but your mixture is being lean
make it shot
FC with FULL exhaust and no fuel enrichement is just asking for it pereiod
period*
4:48amPeter is offline.
4:48amPeter is online.
4:49amMe
i thought stock psi is around 6
4:49amPeter
no
4:49amMe
and im pretty sure bossting somewhere around 8-9
4:49amPeter
here let me find it
thats s4
se is like 8
4:50amMe
mine is s5
4:50amPeter
do you have a FCD ?
well i wonder why so low
4:50amMe
yeas i have a Rebic
rebic is a three in one Fuel computer + FCD + Rev Limiter Disable
also speed limt disable LOL or japanese cars
for*
4:52amPeter
yea
trust right?
4:53amMe
Yup oldschooll hahah
4:53amPeter
also i dont know what your taliing about
rx7 got no rev limiter
4:54amMe
Dude for real?
4:54amPeter
yea
4:54amMe
what do you think fuel cut is??
4:54amPeter
i taken mines when overbosting to past 8k all the wat back to 1.5
fuel cut id for when your care boost spikes
4:55amMe
ok try to take over that
4:55amPeter
is
not for rev limit
there is none on a rx7
take over?
fuel cut is only for overboosting
not rev limiter
lol
4:55amMe
dude N/A has fuel cut
4:56amPeter
haha
4:56amMe
and N/a engine has fuel cut dude
4:56amPeter
not turbo ii
not for over rev
idk about na
4:56amMe
yes a turbo 2 does too
4:56amPeter
i know it just dosent rev any higher
rev limiter?
no it dosent ****
lol
i taken a stock turbo II
stock ecu
past 1k rpm
back around
thats like 10k rpms
just with fcd f con and rb and filter
dude
its only limited by the ports
and exhaust
not the fuel cut
lol
thats why rx7 have a buzzer
no rev limiter
4:59amMe
wait i think ur wrong
the needle physcally can not wrap around
grab one of those cluster u have sitting in ur basment and try to move the needle it wont go past 8
5:00amPeter
dude
your dumb
trust me it will do it
i dont it
WTF
you just cant or never done it
kid im 32
been driving rx7 for 17+ years
trust me
u got a na tach in there
it will do it
trust me
it will wrap around!
you can ask all my rx7 friends who been there
your just too ***** to try
do it
watch it will do it
lol
5:02amMe
my car doesnt have a rev limter dude
5:02amPeter
duh
5:02amMe
my rebic has a rev limter cancel
5:02amPeter
no turbo II does
no rx7 does
maybe the rx8
if im wrong u can but me steak
lol
5:04amMe
i dont knwo where uu got the idea that all rx7's dont have a rev limiter
i remember arguing at ur house about that too
5:04amPeter
you are funny
watch
all rx7 rev hgh
if u got a p port
and stock ecu
it goes to 11k
todd ho does it
tony does it
na
turbo II
5:05amMe
dude sl on the gas for 1 hour straigt... it will not over rev
5:05amPeter
you have to limit a rx7
peoiple add limiters to rx7
5:06amMe
yea mazda did
5:06amPeter
no
thats why rx7 have ******* buzzers man
you dont know ****
they have no limiter
so they can overrevv
while in a turn
they were made that way
its limited by exhaust
and port
turbo can rev high on higher boost
causeit can bypass the ports limits by pushing it in
non turbo needs porting
dude
street ported rx7 on stock ecu can rev to 9500
10k
with intake and exhaust porting
on a stock non modified ecu
i dont know what you think you know but its wrong
take it form someone who woned 34 rx7's
and still owns 3
we will argue forever
and while im revving at 10k smoking your *** in my turbo GTUs
you will find out
ou are limited by either your air filter
porting
or **** engine
idk
who gave you the idea rotary has a rev limitewr
fool
fool
they DO NOT ******* HAVE THEM
5:09amMe
im telling u they do
5:10amPeter
and you are wrong
100% wrong
5:10amMe
nope ur wrong
lol
5:10amPeter
lets make a bet
5:10amMe
ok
5:10amPeter
i get to peepee on you
lol
5:10amMe
lets make a bet
5:10amPeter
HAHAHA
5:10amMe
hella no
you buy dinner if im right
i buy u dinner ur right
5:12amPeter
ok fair bet haha
rx7 have no rev limiter
they just overevv and lean out
then blow a seal
5:13amMe
ok
5:13amPeter
they stop revving because the port limits flow
lol
go google and search
5:13amMe
can i post this on rx7 club then?
5:14amPeter
sure
ask if rx7 have a stock rev limiter built in that stops rev
i dont use the rx7 club
anymore
they suck ***
all noobs like you
lol
dude
watch
when i swap
my 91 turbo engine and stock turbo
into the GTUs
ect
ect
i will show you it rev past 9k rpm
easily
5:16amPeter
https://www.rx7club.com/showpost.php...3&postcount=24
5:18amPeter
there are 2 sides on the forums too
yes and no
people saying ther eis a ignition cut
but i never experienced it
and my turbo II revved up to 1rpm
past 8 on the stock s5 turbo II dash
and henrys turbo II did also
but we did both have f cons
5:20amMe
https://www.rx7club.com/showpost.php...8&postcount=30
https://www.rx7club.com/showpost.php...5&postcount=32
5:21amPeter
that what he says
that is not proof
https://www.rx7club.com/showpost.php...6&postcount=18
from the same post
5:22amMe
https://www.rx7club.com/showpost.php...0&postcount=33
5:22amPeter
he goes past 9
he dosent know **** either
5:23amMe
facepalm
5:23amPeter
https://www.rx7club.com/old-school-other-rotary-63/how-far-should-my-tachometer-go-877349/
read thius dork
PALM SLAP!
lol
and thes e guys got 8000 posts
lmao
and they dont know
you all dont know ****
it is not a limiter
its jsut the rx7 running out of lungs!
the stock intake sucks **** man
a turbo II can go to 1 on the stock tach
and see S4 they know for sure dosent have a limiter
watch
5:27amPeter
https://www.rx7club.com/showpost.php...0&postcount=10
read this
its about fuel cut and boost cut exct
and stock turbo hitting 15 psi
5:30amMe
yea but thats not a factory mazda manual
5:31amPeter
what do you think
factory rev limit is?
5:31amMe
yup
it sure does
5:31amPeter
whatdo you think
it is
i been past it
in a streep port GTUs
stock ECU and injectors
10k rpm
and my turbo II to 10k rpm also
5:33amPeter
argh
everybody on the rx7 clud are morons these days
im reading hella BS
lol
5:33amMe
I think you owe me dinner
lol
hey i want this stupid argument to ruin our friendship alright dude?
dont**
i dont LOL
5:34amPeter
lol
i dont owe you dinner
lol
yet
ima show you
whatever you read online is bullshit i hopeyou know
i never hit a rev limiter in a rx7
hit hit fuel cut yes
bot rev limiter hell no
5:35amMe
Fuel cut is a rev limmter... the ecu pulls fuel to limit the revs dude
5:36amPeter
no
on a rx7
it reached a capacity
66% whatever you said
that not rev limit
thats fuel system limit
and wlet me figure it out too
lol
ima searching
ima have to call mazdatrix or rb on monday
lol
if you right
im not your friend anymore
lol
HAHAHa
ima rev to 10k rpm anyways
and show you off
5:38amMe
awww dude for real?
5:38amPeter
haha im iddiing lmao
5:38amMe
ur gonna let this ruin our friendship
5:38amPeter
kidding
what friendship lol
lol
ol
your funny
how could this ruin something lol
5:39amMe
lol i know but we have at meets driving around lol
fun
5:39amPeter
i can buy you dinner if your right
at mcdonalds
lol
its ok i can still drive better then you
haha
5:40amMe
this is true
u are a better driver
ive only been driving for 3 years
lol
5:40amPeter
i wonder
was it my s4 or s5
cause s4 dont have them for sure
3 ytrs
wth
lol
5:41amMe
yup
got my DL at 18
and im 21
5:41amPeter
lol
5:42amMe
and yes s4 do have them i my first seven was s4
5:43amPeter
my first 7 was a s4 86 sport
never revved that high
around 8500
all my rx7 8500
except turbo II
i had f con and it went to 1
watch
5:45amMe
my friend marc.. has a street ported n/a sport.. and with open exhaust only.. his limmieter hard up 7800 and the bangs at 8.. he could going up his power band but his limter wont let him (also known as Fuel cut)
hits hard at*
5:46amPeter
what car?
5:46amMe
red 86 sport u never met him
5:46amPeter
7800?
tat is low
i did higher then that
with a stock motor
5:46amMe
he went to the concord meet
5:46amPeter
full rb exhaust
streetable headers
silencer
hks mifflers
and intake
droip in kn
wtf lmao
my gsl se revs to 8000
lmao
and dosent hit ****
5:47amMe
does it go past 8?
5:47amPeter
never taken it past
but i will now
try for 8500
5:47amMe
then ull never know
5:47amPeter
after i pout a full exhaust on
hell yes
it will
not with stock exhaust
but it hits 8 for sure
lets race
i think i can smoke you
lol
from 0-60
i say im pulling a mid 15
stock turbo II does 15 flat
so u got exchaust ect
u might be pulling 14-14.5
maybe faster
if u can drive it right
lol
5:49amMe
if u didnt have a rev limiter ur car can just keep reving eventually the flywheel nut will spin soo fdast it will lossen upp and the flywheel will slice through the floor panel and chop ur feet off
5:49amPeter
the flyuwheel nut cannot spin off
hello
its backwards threadded
lol
it will just shatter
lol
unless you have one that is balanced and billet forged steel
made for high revs
rx7 rev up to 13k rpm
with mods
idk about stock rev limiter
never hit it
just run out of power
then shift
but in ported
i been to 9
no power loss
and turbo II boost creeping with non ported WG back to 1
i wonder if the f con has anything to do with it
i doubt it
i doubt it
Old Jun 13, 2010 | 08:03 AM
EvanchiX's Avatar
Damn, you saved all of that!!!
Old Jun 13, 2010 | 08:51 AM
wakazz's Avatar
Bay Area Rotary
THere is more tooo it but i dont feel like posting it... He later goes on to say there is a rev limiter but its ignition controlled. He thinks it cuts the spark and not the fuel
Old Jun 13, 2010 | 09:18 AM
slpin's Avatar
7th Heaven
Fuel & Emissions chapters, pages F1-77 (NA) and F2-75 (Turbo), Output Devices table, first line, Fuel Injection Amount, Remarks:
"Rear side; Above 8,500rpm; Fuel cut"
It is a rear rotor fuel cut to limit rpm.
Old Jun 13, 2010 | 01:25 PM
DeMoe Aurelius's Avatar
Teeterin on Grip & Drift
That post just gave me a headache!!!
Old Jun 13, 2010 | 01:54 PM
rotary#10's Avatar
Vodak
In my first 7 i used to rev the motor up to 9k ! LOL once you go past 8k your into carbon clean up mode. It came stock on all n/a fcs, but most owners don't use it. You don't make anymore power pass redline. Your just free spining the engine.. IN an N/A. Turbos are different since you have the turbo bringing in more air.
Old Jun 13, 2010 | 02:36 PM
RotaryEvolution's Avatar
Sharp Claws
can i have my 2 minutes of my life back? i couldn't read past about the 10th swap of words
OP, he is right, you don't need more injectors with a hybrid turbo because it just adds another possible failure point reducing the reliability of the engine.
in the end, he seemed more knowledgable than you do.
Old Jun 13, 2010 | 04:55 PM
RotaryDreamz's Avatar
INCREASE THE PEACE
damn son, almost a 2 hour chat bout this at 4 in the morning. Needa lay off that ICE.
Old Jun 14, 2010 | 10:42 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Not even babelfish could make sense of that...
Old Jun 14, 2010 | 11:19 AM
ReZ311's Avatar
KM48 Burnout
Old Jun 14, 2010 | 02:51 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
rotary is rev limited when it stops running because you kept your foot in it long after the buzzer went off.
Old Jun 14, 2010 | 05:29 PM
DJDINO's Avatar
CEO of Belligerents INC.
What is this thread about? Cliff notes anyone?
Old Jun 14, 2010 | 05:32 PM
Brismo7's Avatar
6 Speed FC
TL;DR
Rotarys can spin to 30k if you take off the Rev Limiter. They rotate, not go up and down like a boinger. <--Fact.
Old Jun 14, 2010 | 06:35 PM
-Crash-'s Avatar
89FC
OP, your buddy knows way more than you do man lol, AFC does control the fuel, you don't need 6 injectors lol, yes the s5 does over boost when you open up the exhaust (RB exhaust), i didn't read much past that, but in the end...YOUR WRONG lol listen to your buddy he knows his ****.
Originally Posted by Brismo7
TL;DR
Says the guy with the pistons lol, but its true to a point, IF the keg is balanced to spin that high, along with a ton of other crap, like if the tensile strength of the stock components can take that rpm it will keep spinning.
Here I’ll state it better for you, the design of the rotary engine can have unlimited RPM’s.
Old Jun 14, 2010 | 06:56 PM
GREENMAN!'s Avatar
the rotary engine is poorly designed and ultimately will be forgotten forever.
Old Jun 14, 2010 | 07:01 PM
ReZ311's Avatar
KM48 Burnout
Automatics have rev limiters.
Old Jun 14, 2010 | 07:35 PM
DCrosby's Avatar
No it's not Turbo'd
Does this post have a rev limiter ? Because I'm about to shoot someone... the stupidity in that first post is immeasurable.
Old Jun 15, 2010 | 11:11 AM
stealthcmos's Avatar
Yeah that Peter Jun guy is a moron! Tried to call my Sport a SE. And still believes he know everything just because he is 32 or w/e. Like he really stresses how old he is makes him smarter then everyone around him. I wouldn't let him touch my car. Like really WTF? Stupid....
Old Jun 15, 2010 | 02:02 PM
Well, give him a chance to mature a bit, and maybe he'll wise up some. Once you get old enough you begin to understand that you STILL don't know more than you know.
Only 32? I've been driving longer than he's been out of diapers.
Old Jun 15, 2010 | 02:53 PM
magus2222's Avatar
On the fasttrack!
ill just say this, peter knows his ****. maybe he doesnt understand the full dynamics of absolutely everything. no one does, not alan, not peter, not even aaroncake. BUT, these guys do know WAY more than even i claim to know.
as for the attacks on other people, calling names and such, sorry, but all of you guys, jonny, marc, daren, sean, YOU ALL have **** to learn, ALOT of ****. but, thats fine, if you continue to learn and grow, then thats what life is all about.
all i know is that i have alot to learn just to be able to do my monster REW swap and build my drift car the way i want.
Lloyd
Old Jun 15, 2010 | 03:40 PM
Brody8877's Avatar
#FakeCarEnthusaist
im not reading this....
Old Jun 15, 2010 | 04:08 PM
magus2222's Avatar
On the fasttrack!
cliff notes!*
7s have rev limiters and fuel cut
no they dont
yes they do
im older and know more, stfu kid
no you shutup old man
posts thread
Lloyd
Old Jun 15, 2010 | 06:36 PM
rotary#10's Avatar
Vodak
Lol!
Old Jun 15, 2010 | 06:38 PM
rotary#10's Avatar
Vodak
With our combined knowlegde we can rule the rotary universe, but instead we fight like the Sith from star wars.
Old Jun 15, 2010 | 06:50 PM
rotary#10's Avatar
Vodak
@DivinDriver. I know what you mean.
