50/50 to 75/25 mix...
Old Jun 12, 2010 | 03:02 PM
sen2two's Avatar
Rx2 > FD
Im running the boost juice mix right now (49 meth/51 water) and i want see how my car does with a 75/25 mix, or close to it.
How much meth should i add to my 50/50 mix to make it a as close as possible to 75/25?
Old Jun 12, 2010 | 05:03 PM
Groshuk's Avatar
To get to 75/25 you need to add an equal amount of meth to whatever volume of 50/50 you are using, eg. if you have 1 liter of 50/50 adding 1 liter of meth gets you to 75/25. Same goes if you have a gallon of 50/50 you add a gallon of meth.
Old Jun 12, 2010 | 07:04 PM
haydenw's Avatar
do it by weight, it is more accurate than volume (as Air- Fuel Ratios are by weight)
I hope you are going to get it retuned when you change the mix ratio
Bathurst
Sep 10, 2004 08:37 PM
Wargasm
Aug 25, 2004 12:05 AM
RX-Heven
13
Aug 21, 2004 04:08 AM
blackmr2turbo
53
Jun 20, 2004 07:55 PM
seventhgear
May 30, 2003 01:56 PM
