Power FC one time start.. now nothing..please help
Old Jun 12, 2010 | 11:50 AM
okiedoke's Avatar
ok so i tried reading other threads on this but nothing is exatly like my set up so im stuck.. i need help..
car: 1987 rx7 tII
mods:
fresh rebuild
large street port
550prim 1600 sec.
fmic
bov
3inch full exhaust
PFC ( obviously)
now the car started once and ran for an hour or just over....but i had set the injectors to 45% but then turned them up to 100 while it ran... just to see what would happen...
now i dont no much about adjusting this stuff and dont wanna mess it up...
but i got the pfc used ( with commander) and im assuiming it didnt come set back to basemap is there a way i can do that on the commander? and reset it all ?
also the car just floods now every time i try start it... i have a switch for the fuel pump cutt off to try prevent that but it just floods constantly....
i de flood it every time but still nothing...
can any one help me out with what things i should adjust or reset or anything to get my fuel down and let it run and reset my pfc or something...
also fpr was set at 40 for when it ran...
please anyone ideas pleasee
Old Jun 12, 2010 | 01:05 PM
okiedoke's Avatar
just wanted to add i checked the sensor check page...and i have 2 things highlighted and that is vmop: 0.00 and fuel 4.98
Old Jun 14, 2010 | 01:01 AM
cewrx7r1's Avatar
Eye In The Sky
Get the PFC manual, read it and learn. It does tell you how to re-initialize the PFC.
BUT: it will take a DATALOGIT to set the secondary to back to1600 if they were already that way.
Old Jun 14, 2010 | 06:44 AM
Banzai-Racing's Avatar
Rotary Specialists
Here is the instruction manual http://www.banzai-racing.com/store_i...werFC_FD3S.pdf
Vmop is the electronic oil metering pump which your car does not have
Fuel is the Fuel temp sensor which you also do not have
Depending on the map sensor you are using, initializing the PFC may put you in a worse spot then you are in right now.
Old Jun 15, 2010 | 04:06 PM
okiedoke's Avatar
well i got it used....so no manual....thanks for the link tho....and clearing up the highlighted sensors...
so should i reset it or no ?
Old Jun 15, 2010 | 05:53 PM
Rotary Specialists
Do you have this installed with our adapter harness? What map sensor are you using? If it is the GM 3 bar then do not reset the PFC as you will lose the ability to select that map sensor.
Old Jun 16, 2010 | 12:34 PM
okiedoke's Avatar
yes is it with 3 bar map sensor...and yes with your adapter harness....
thanks ill see how it goes...
Old Jun 17, 2010 | 11:46 AM
cewrx7r1's Avatar
Eye In The Sky
Was the current map even set up for a 3 BAR?
You need an experienced PFC/DL person to check your setup with a DL which you have not mentioned!
It is beyond your current knowledge base.
Old Jun 18, 2010 | 04:23 PM
okiedoke's Avatar
yes it is beyond my knowledge base....havent even had the car a year i dont no every thing clearly.... i spoke to the guy who did my short block rebuild and who supplied the pfc and he said i have to get it running and then 500km they will do my tune for me....but i assumed that i would need some basic adjustments to even get it to the point to where i can drive it to get to 500km....
all of this is just depressing...car has been sitting for weeks cause i cant get it to not flood...
Old Jun 18, 2010 | 04:41 PM
Rotary Specialists
If the PFC map is not set p for the GM 3 bar it will not run properly. You can not just run an S4 FC with the stock PFC FD base map.
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
