Steering Questions
Old Jun 11, 2010 | 06:21 PM
GreenMachine's Avatar
Steering Questions
In my Steering there is quite abit of play in the wheel. What would help tighten that up?
Sway Bars?
Polyeurathane Bushings?
Thanks
Shea
360
Old Jun 12, 2010 | 12:49 AM
rxtasy3's Avatar
depends on what yr model ur referring to. the fb can be adjusted out, usually. been covered quite a bit here.
Old Jun 12, 2010 | 07:34 PM
alexisthemovie's Avatar
Newbie
worn rack & pinion or worn tie rod ends... - usually
Old Jun 14, 2010 | 11:54 AM
Kentetsu's Avatar
If this is referring to a 1st gen, then read this: https://www.rx7club.com/showthread.p...steering+grind
matty
Jan 18, 2020 10:39 AM
c0rpse
Aug 25, 2015 11:50 PM
