non-seq and pressure chamber?
Old Jun 24, 2002 | 01:12 AM
OK I was just doing some thinking while looking over the vacuum diagram and it seems to me that with the non-sequential set-up that the pressure chamber would no longer be needed. Since all it does is supply pressure to open the TCA (RIGHT?). Someone please correct me if I am wrong and explain what it would do for a non-seq set-up. The reason I am wondering about this is I had the check valve break on me (the one that goes to the pressure chamber) and before I spend 40.00 at mazda for a new one I needed to know if I really need the pressure chamber?
Old Jun 24, 2002 | 02:54 AM
DK's Avatar
DK
40k worth of fail
You don't need it. You don't need any of the vacuum chambers anymore.
Old Jun 24, 2002 | 08:24 AM
Flybye's Avatar
It's never fast enough...
The pressure chamber on top of the engine goes byebye and so does the vacuum chamber behind the power steering pump.
By the way, the HELP check valves at Napa for $5 work just as good, even though they have a slightly smaller nipple. Well, at least I have no complaints
13
Jan 9, 2018 11:19 AM
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
j_tso
1st Gen General Discussion
Sep 11, 2015 09:33 PM
t-von
Sep 10, 2015 01:56 PM
