auxilary ports?
Old Jun 8, 2010 | 11:20 AM
dkaszak88's Avatar
NJ auxilary ports?
how do i check if my 5th and 6th port are funcioning properly?
Old Jun 8, 2010 | 12:24 PM
RotaryRocket88's Avatar
Top Down, Boost Up
http://www.aaroncake.net/RX-7/6porttest.htm
Old Jun 8, 2010 | 01:36 PM
canonize-ryda's Avatar
well the easiest way iver heard is to smear grease on the actuatorshaft and drive around a little going over 4k rpm(3800) and see if it smeared upwards and if not ports arent opening (if your running stock exhuast and still have your cat then u should be fine. what year car? if its 88-91 they runn off the airpump so make shure your airpump is working
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
