Just bought a Nardi Deep Corn Steering Wheel, which hub do I need?
Old Jun 7, 2010 | 10:27 PM
Viking War Hammer's Avatar
*** Bless The USA
Unhappy Just bought a Nardi Deep Corn Steering Wheel, which hub do I need?
Just picked up a Suede Nardi Deep Corn Steering Wheel and went to install it, bad news; it has a different bolt pattern than my current hub. I think I currently have a Pilot hub.
What hubs are available? I would like something as short as possible. Not high dollar, maybe in the $100-$120 range?
Old Jun 7, 2010 | 10:39 PM
Hey Eric,
There are only two patterns that I'm aware of, momo and nardi. If you buy a nardi/momo adapter ring you should be good to go
Old Jun 7, 2010 | 11:01 PM
*** Bless The USA
Thanks Rich, I just ordered this adapter.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Jun 7, 2010 | 11:40 PM
*** Bless The USA
Another question, my horn button seems too small for my wheel. Will it snap in place without the wheel being mounted up? Strange..
Old Jun 7, 2010 | 11:59 PM
RLaoFD's Avatar
Brappable not Unflappable
what it does is snap into the hub. if the spacer is too shallow, it will not stay in place. Thats what happened to mine when I bought the NRG spacer. I just put washers to space it out just a little. That allows that metal clip inside the bottom of the horn to stay in place.
Old Jun 8, 2010 | 12:17 AM
*** Bless The USA
Do I need some sort of trim ring between the hub and wheel? If so, I don't have one.
Old Jun 8, 2010 | 01:05 AM
RLaoFD's Avatar
I'm pretty sure you do, because your spacer is the same size as mine. Wait and test fit before doing anything though because your spacer is a different brand/model.
Old Jun 8, 2010 | 08:38 AM
You also probably have a momo-sized horn, which are smaller than the Nardi horns. Didn't the deep corn come with a Nardi horn? Regardless, you need a ring which goes between the hub and the wheel.
Does the horn button work on your setup?
Old Jun 8, 2010 | 09:43 AM
*** Bless The USA
It came with a Nardi horn button, but it fits loosely in the Nardi hole.
Thanks, I ordered this ring. I hope it's the right one.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Jun 8, 2010 | 12:14 PM
*** Bless The USA
So, did you have the same problem as I did? What does your horn button snap on to? The wheel itself or the trim ring or spacer?
Old Jun 8, 2010 | 02:48 PM
RLaoFD's Avatar
looks like you'll be set with that retainer ring. didn't know they had those. LOL
Old Jun 8, 2010 | 04:27 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
I used a Works Bell hub... the Nardi horn fits right in the ID of the hub. It also comes with SRS resistors/fuse and everything...
Bought everything from http://aspecproducts.com/
Btw, I got the suede too, love it.
Old Jun 8, 2010 | 05:13 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
let me know if your horn still doesnt work
Old Jun 8, 2010 | 11:26 PM
The horn wire is green with a red tracer, I extended mine with a female spade connector. Driving in NJ without a horn is close to suicidal as I found out the hard way
Old Jun 9, 2010 | 12:03 AM
MODERATOR
L.A. traffic too
Old Jun 9, 2010 | 02:56 AM
Juan's Avatar
Im a tall midget.
Originally Posted by Alex Rodriguez
L.A. traffic too
Unfortunately our horns sound like they came out of a Power Wheels to be effective
Old Jun 9, 2010 | 05:17 AM
Wo:Deep's Avatar
DAMN!Nice
My buddies 200SX Compressor surge is louder then my horn.. haha
Old Jun 9, 2010 | 08:05 AM
That's why I'm rocking Hella Supertones
Old Jun 9, 2010 | 12:24 PM
*** Bless The USA
Originally Posted by gmonsen
Hammer... The button snaps into the hub. There should be a chrome trim ring that does around the button. I would have gotten a hub meant for the Nardi, like Pandoz and I did. Great wheel, though the Classic without the deep suits my driving style better.
Gordon
Well, I already had a hub and ordered the parts to make it fit so I guess I’m stuck with it now 
Yeah, we’ll see how I like the deep corn. I’m not sure if the wheel sitting closer to me is a bad thing or good thing. I already sit leaned back since I’m a big guy so I’m not sure if it will be too close or not. Either way, the wheel feels great.
Old Jun 9, 2010 | 12:31 PM
RLaoFD's Avatar
The way you did it, the wheel doesn't sit much closer to you since the stock one is so bulky. If anything you'll have more space because the deep corn (if in 330) is drastically smaller. I can tell you right now im practically running your setup and there is def. more room.
Now that I think about it im not sure if you're running what I am. Do you have a quick release? if not you will be fine. With a shorter hub and spacer, you retain the ability to "flick" the turn signal instead of lifting your hand off the wheel. If anything your hand is closer to the switch becaus of smaller diameter.
Old Jun 9, 2010 | 01:33 PM
*** Bless The USA
Nope, not running a quick release. Is that what you're running?
Old Jun 9, 2010 | 10:39 PM
RLaoFD's Avatar
No I'm just running a short hub, a quick release would bring the wheel more forward and give you less space. You shouldn't be worried about this since you don't have one. With that retainer ring you bought, everything, including fitment should be fine.
Old Jun 10, 2010 | 11:31 AM
*** Bless The USA
Problem,
I got my adapter today, it fits the Nardi steering wheel bolt pattern but doesn’t fit my hub bolt pattern. Can someone just tell me which hub to order? I don’t want to drop $200, though. I see the NRG short hub for $120, is that all I need to make this work. I won’t be using a quick release.
Old Jun 10, 2010 | 11:48 AM
PandazRx-7's Avatar
www.aspecproducts.com They'll hook you up with the Works Bell hub, definitly under $200. With the 350mm and regular WB hub, I think I gained 2"... if you're around 6' tall it will feel much better with the seat back and legs extended. No more legs hitting wheel. If you want to stay close to stock height, get the slim hub.
Sorry crappy phone pics...
Old Jun 10, 2010 | 01:34 PM
*** Bless The USA
Thank you ^^^. I sent them a email.
Question,
Will the short NRG HUB work by itself or is it meant to be used in conjunction with their quick release?
