Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Question on Float Drop in Nikki Carb
Old May 27, 2010 | 12:01 AM
rotordogg's Avatar
Customizer
I am rebuilding the carb and per the instructions I took measurements of the two floats in the "Dry" and "Drop" positions. In the Drop position, both floats are exactly the same distance. But in the Dry position, one float is 10mm higher than the other. Is this normal or is there something I need to adjust? Is there a list somewhere that explains what the factory spec Dry and Drop measurements should be?
Thanks, Scott
whinin
Mar 30, 2019 07:53 PM
jsesq
27
Sep 25, 2015 11:10 AM
AXA
Sep 5, 2015 10:06 AM
