Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
What boinger engine for a Lemons car?
Old May 25, 2010 | 11:11 PM
jgrewe's Avatar
GET OFF MY LAWN
I've got an FC outside the shop that may end up at the Florida PBIR Lemons race if I can come up with an engine and tranny to weld into it with some cut up coat hangers.
The $200 question is what is the easiest CHEAP piston engine to drop in the car? I'm thinking the sump location is the biggest problem. Fabrication is no problem, I just don't want to take the time. So 4,6,or 8 cyl., something I can run on a carb and hopefully its available in some P.O.S. car I can find on craigslist.
One option I've found in the business park my shop is in is a Buick of some sort that has a 3800 V6 AND IS fwd. It looks like I could take the whole front subframe/driveline and put it in the back of the rex. A lot of work, but it might be fun to make an abortion like that.
I don't want to waste a 13B on a car that probably won't come home.
Old May 30, 2010 | 11:18 PM
jgrewe's Avatar
GET OFF MY LAWN
54 views and nothing? There are a bunch of good engines out there, I'm just looking for something strange or simple or both.
The mid engine Buick driveline is looking better and better.
Old Jun 1, 2010 | 05:26 PM
fstbckgt's Avatar
Barrel Roll
cheapest rwd option would probly be some sort of v8
rx7brandon
Aug 16, 2015 10:55 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
