Lower Intake Manifold Gasket possible leaking
Old May 23, 2010 | 06:01 PM
insanekiller18's Avatar
Hi I have 1988 RX7 convertible the car would not keep idle. would rev to 3,000 RPM then die. I had the car smoke tested and they said it was the intake gasket. I bought the lower intake and middle gasket. changed the middle gasket that goes on top of lower intake. Started her up then it died. I got out and look at the lower intake manifold it is leaking gas I think that is where it is coming from. Do you guys think that it is just the lower gasket or something else?
Old May 24, 2010 | 10:18 AM
Aaron Cake's Avatar
Engine, Not Motor
The lower intake gasket can leak, but it's not a normal failure.
Did you plug in the AFM? If it is unplugged, the car will start, rev up, and then die.
Old May 24, 2010 | 04:33 PM
datz's Avatar
GNARKILL
liquid gas or gas vapors?
FD7KiD
15
Feb 26, 2021 10:12 PM
