tranny lost 5th and reverse
Old May 19, 2010 | 03:08 PM
rex7rida's Avatar
rx7 fan for life
NY tranny lost 5th and reverse
ok so i was driving to the local autozone to get a few cleaning things for my fd and i did my shopping in 15min came outside and i had no reverse at all. It felt like it locked itself out . SO i used a little force not much at all and still nothing so i pushed the car out of the parking spot and started to drive it . well all my shifts were easy as always except when i was about to shift into 5th and i got a grind like every fd owner talks about .but every time i go to put into 5th now i get a grind and no movement at all from that gear either. But i had all my gears going to autozone. i just cant fiqure this out . this is the second tranny ive put in this car .ive got a twin plate clutch , i changed the fluid and still nothing . Can somebody please point me in the right direction with this . Thank you
Old May 20, 2010 | 08:49 PM
dgeesaman's Avatar
Pull the transmission and remove the tailhousing. Then remove the rear bearing plate to get in where 5th gear is. I'll bet something broke and got loose within the 5th/reverse housing and is blocking the shift mechanisms.
David
Old May 20, 2010 | 09:14 PM
rex7rida's Avatar
rx7 fan for life
Ok. thanks david . i will take it to my buddys shop this weekend . i just find it funny i drove all the way to queens today from long island and got stuck in traffic for almost 2 hours and from 1st to 4th it was fine .this sucks
Old May 20, 2010 | 09:16 PM
rex7rida's Avatar
rx7 fan for life
and david my friends call me pat nice to meet you. thank you again
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
Jetlag
Sep 29, 2015 06:52 AM
