argh....stutter at low rpm
Old Jun 22, 2002 | 11:21 AM
Vohaul's Avatar
hey guys,
this moring i get up to go out..and car barely moves..coughing and stuttering etc..backfiring like crazy etc., idle is a little lower than usual...
so...sigh..since i missed my appt. anyway, i open the hood and find my battery has come free of its moorings and is resting on the distributor....and there seems to be battery water / acid on the plug wires etc..
so i tighten up all the plug wires, (one coil was loose) shut hood, go for a drive....
now, no problems after 2500 rpm, car accelerates smoothly and nicely in any gear..lower thatn 2500, missing and backkfiring like crazy...
i checkd for loose plugs etc. hoses...none i can see....
any ideas?
Paul
Old Jun 22, 2002 | 02:17 PM
Pedestrian X's Avatar
SpAz!
check the hoses raound there... mebbe the acid ate through one of them? just a guess... is there a hissing noise like air beign sucked through a straw or anything?
Old Jun 22, 2002 | 02:56 PM
Vohaul's Avatar
no..no hissing noise......sigh....
i was just out there and i blocked the shutter valve hose
didnt make much difference....
you know, do you think maybe it knocked the distributor loose..moved the timig maybe?
hmm..ill go chck that in a bit
Old Jun 22, 2002 | 03:59 PM
abeomid's Avatar
maybe you've got some acid inside the distributer or something
Old Jun 22, 2002 | 04:39 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
did you look at the rotor in the dizzy. when I first got my rex the battery wasnt tied down and it slid into the dizzy and the half of the rotor was destroyed.
Old Jun 22, 2002 | 05:19 PM
Vohaul's Avatar
good call..ill go have a look.....
its also idling at semmingingly about 400-500 rpm....
whereas yesterday it was doing a rock solid 750
Old Jun 22, 2002 | 05:31 PM
Vohaul's Avatar
well, the rotor seems intact, but old, and the cap...the points inside seem worn out heavily.....which is probably a god place to start..but i just cant figure out why it started so suddenly....
also, spark plug wires have battery acid on them.....is it a good idea to replace em?
Old Jun 22, 2002 | 06:45 PM
abeomid's Avatar
The battery acid can eat through those plastic convers, so it would be a good idea to change the plug wires. They are fairly cheap from mazda.
Old Jun 22, 2002 | 08:00 PM
Vohaul's Avatar
k..will do....it needs a tune up anyway..so new cap , rotor, plug wires, plugs..oh.and that pesky manifold gasket......i love rx-7's
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
