1986 RX7 injectors
Old May 16, 2010 | 11:37 AM
popsboomie's Avatar
FL 1986 RX7 injectors
installed a new 13B engine in my 1986 RX7 and now have constant voltage to the injectors. I think they are supposed to pulse but don't know where to start looking. Any help is greatly appreciated
Old May 16, 2010 | 03:26 PM
farberio's Avatar
NASA-MW ST4
They are supposed to pulse, look for a short in the wiring.
Old May 16, 2010 | 03:56 PM
RotaryRocket88's Avatar
Top Down, Boost Up
No need to look for a short. A multimeter can't detect the pulse of an injector. It will just show up as constant power.
Old May 16, 2010 | 07:41 PM
RaceTUNE's Avatar
Bearo
You will need a Noid light or a Scope to see the pulse, with a mutilmeter it will show constant voltage. And make sure when checking injector pulse your car cranking the starter or the injectors will not pulse.
-Frank Siharath
Old May 16, 2010 | 08:08 PM
farberio's Avatar
NASA-MW ST4
If your multimeter can measure frequency it can measure the pulses.
Old May 18, 2010 | 12:32 AM
calpatriot's Avatar
There is supposed to be constant voltage to the injectors. The ECU fires the injctor by pulling the other pin to ground.
FD7KiD
15
Feb 26, 2021 10:12 PM
The Shaolin
Sep 14, 2015 07:50 PM
FD7KiD
Aug 17, 2015 11:50 PM
