The best lsd & manual trans oil?
Old May 13, 2010 | 12:03 AM
FD7KiD's Avatar
2SoonJr
hey guys
so this is going to be my first LSD & MANUAL TRANS oil change and i was wondering which oil and weight would you guys recommend for my FC? i was thinking of going with Royal Purple or Motul but my concern will these lock up my N/A diff?
and also have any of you guys used
Ford or GM friction modifier in your gear box? or if there is a better one out there all info would be helpful
thanks
Ricky
Old May 13, 2010 | 10:58 AM
Kentetsu's Avatar
For manual trannies, I've always used a 50/50 mix of gear lube and ATF. Keeps the synchros clean and moving freely. Never had an issue with it, and it always improves shifting. Been doing this for over two decades since I read about it in How to Hotrod and Race your Datsun.
Old May 14, 2010 | 12:25 AM
FD7KiD's Avatar
2SoonJr
thanks bro ill look into that
has anyone used Mobile 1 in there manuel transmission
Old May 14, 2010 | 03:54 PM
TrentO's Avatar
I've run Redline in my stock boxes. They seemed pretty happy with it.
That said, I did explode two of them before swapping in the T5 Dogbox (both 3rd gear failures, under hard road racing conditions, with an unsprung dual disk clutch and 400rwhp)
-Trent
Old May 14, 2010 | 06:04 PM
gawdodirt's Avatar
Been here since dirt...
I have only run Mobil 1 in everything racing for years. Never a lube failure.
Most any synthetic is a good bet. Only gear lube in the trans and diff. No ATF.
Friction modifiers were for clutch type LSD's.
GD
Old May 16, 2010 | 12:41 AM
13b_cookie_monster's Avatar
ARE wheel whore.
neo gear oil. mazdatrix sells it. also redline works good
Old May 21, 2010 | 12:20 AM
lazyguy35's Avatar
I RUNmotul gear 300 75-90 in my trans for my fd and the trans feels nice and smooth under all conditions.
Old May 21, 2010 | 11:56 PM
soza127's Avatar
good info guys thank you keep posting
Old May 27, 2010 | 07:25 PM
FD7KiD's Avatar
2SoonJr
have any of you guys used the OIL GEAR ADDITIVE by GM in your differential ??
Old May 27, 2010 | 07:28 PM
ashleyanne's Avatar
They only sell Redline in one store where I live. It's pretty stupid. But yeah, Redline.
Snoopy FD
Dec 8, 2015 01:45 PM
