STANCE 3 WAY FD Coilovers ALUMINUM
Old May 4, 2010 | 11:03 PM
ARD T2's Avatar
Thumbs up STANCE 3 WAY FD Coilovers ALUMINUM
Well after a decently long wait we finally got them.
Here's a front and rear corner of the
Stance GR+3's these were made with Aluminum bodies, special order.
Steel Body GR+3: $3495.00 MSRP
Aluminum Body GR+3: $3895.00 MSRP
Each corner is about 14lbs top to bottom.
Old May 4, 2010 | 11:04 PM
ARD T2's Avatar
As seen here:
http://www.autornd.com/ProductDetail...Code=GR%203WAY
Old May 5, 2010 | 12:49 AM
gracer7-rx7's Avatar
needs more track time
nice looking setup
Old May 5, 2010 | 02:19 AM
Josh18_2k's Avatar
wheres the shock dynos...
Old May 5, 2010 | 02:38 AM
ARD T2's Avatar
I wasn't able to get any. Production was so behind on them they shipped to me right away. I'm hoping that CrispyRX7 will be able to provide us with proper feedback.
Old May 5, 2010 | 10:35 AM
Prometheus's Avatar
Still got it.
I'm Not seing the helper springs in the picture.
Are they included in the kit, or just there an an additional option?
Old May 5, 2010 | 10:58 AM
ptrhahn's Avatar
You shouldn't need helper springs with the separate height adjust.
Old May 5, 2010 | 11:09 AM
kimletrim's Avatar
Height adjustment does not change the spring rates.
Besides, that separate reservoir is not for changing ride height.
Old May 5, 2010 | 12:38 PM
ptrhahn's Avatar
LOL,
Helper springs don't change the spring rate either. All they do is make up the gap with shorter main springs when the shocks are fully extended—they completely compress when under load.
You'll note that the lower portion of these shocks is adjustable independent of the spring perch, so there shouldn't be any reason to have spring slack at full droop unless for some reason it's out of adjustment range. But, either way, helper springs aren't 100% necessary even if you have a gap.
https://www.upr.com/Eibach-Helper-Springs-p726.html
Old May 5, 2010 | 12:48 PM
Rxmfn7's Avatar
Do a barrel roll!
Wow, these are almost double the price of my Zeals (which i thought were a bit expensive). Are they really that good?
Old May 5, 2010 | 01:32 PM
ARD T2's Avatar
Ummms Zeal doesn't even make a Triple Adjustable Coilover.
Your Zeals are single adjustable.
Zeal Double Adjustable Coilovers are around $5000.00, A Triple adjustable from Zeal would probably be around double the cost of this coilover.
PLEASE KNOW WHAT YOU'RE LOOKING AT FELLAS. If you're a normal street guy don't even bother asking any questions. This product does not apply to you.
If you're a track guy you already know what you're looking at and already see the inherent value in the price of this item.
Rishie
Old May 5, 2010 | 01:45 PM
Prometheus's Avatar
Still got it.
Life expectancy?
Old May 5, 2010 | 05:39 PM
CrispyRX7's Avatar
Polishing Fiend
Rishie,
You stealing my thunder?
Crispy
Old May 5, 2010 | 07:32 PM
MakoRacing's Avatar
Where has my $ gone?
^Tell us how they are damnit!
Old May 5, 2010 | 08:29 PM
CrispyRX7's Avatar
Polishing Fiend
As soon as they show up! I don't have them yet - in transit.
crispy
Old May 5, 2010 | 10:33 PM
MaczPayne's Avatar
Mac Attack
Wow, they make them for the FC too... nice
Old May 5, 2010 | 10:48 PM
ARD T2's Avatar
Oh Crispy I had to tease you a bit. I only opened up one of each. I left the others as Bubble Wrapped Virgins.
PLEASE LET ME KNOW WHEN YOU GET THEM. STANCE IS WAITING FOR YOUR CALL SO YOU CAN GET IT SETUP EASIER.
Thanks, Rishie
Old May 5, 2010 | 10:50 PM
ARD T2's Avatar
Life Expectancy????
I guess this all depends on what you're doing with the car and how well you maintain/clean your coils. Also has a lot to do with road conditions. They will last as long as any of the other Stance dampers.
A lot will be revealed after these get out there more. Right now there isn't enough data to answer some of these questions. Hence the discounted pricing we're offering for experienced track drivers.
Thanks, Rishie
Rishie
Old May 5, 2010 | 11:21 PM
CrispyRX7's Avatar
Polishing Fiend
Thanks, Rishie
Yup. And I have a set of recently acquired 18x10 CCW's with new Hoosiers ready and waiting.
Crispy
Old May 7, 2010 | 11:05 AM
Rxmfn7's Avatar
Do a barrel roll!
My apoligies Rishie, I wasn't trying to bash the price of your product. I will admit I didnt look/read thoroughly to see what they were. I was thinking they were the run of the mill stance that was becoming so popular for FDs nowadays. Didn;t realize they were the 3-way adjustables. Not a bad price for that type of setup at all.. although well beyond what I need
Rishie
Old May 7, 2010 | 11:49 AM
ARD T2's Avatar
No problem guys. Sorry been a very long week. Tons of shipments and only 2 arms and 2 legs.
Can't wait for Crispy to get them.
These were in fact confirmed and revalved for 10kg springs in the rear.
Thanks,
Rishie
Old May 7, 2010 | 08:48 PM
CrispyRX7's Avatar
Polishing Fiend
They're here!!
Got the BIG 70lb box today.
So far so good. They look nice - quality connectors. Things like SS C-clips, all anodized hardware, nothing painted or with rough cast edges.... Feel solid.
One thing I will have to do is figure out where to mount the remote reservoirs in the front. The rears will go on the roll bar....the front...ahhh...ummm...well....
FWIW,
Crispy
Old May 7, 2010 | 11:43 PM
ARD T2's Avatar
Awesome crispy.
I spoke with Stance yesterday in regards to mounting of the front remote reservoirs. The only recommendation is to NOT DISCONNECT the external reservoir unless you have access to a Nitrogen Tank.
The Valve Pressure Tool should be there shortly if not already. Obviously if you keep it connected you'll need to cut approx 3" hole so you can pass the res into the engine bay. If it was me I'd probably have to find a place I can get some gas from.
Rishie
Old May 20, 2010 | 02:53 PM
patfat's Avatar
Track junkie
Chris, I mounted mine like this:
I decided that notching the shock tower probably wasn't the best solution for shock tower rigidity. And opted for holes in the fender and modifying the fender liner. Whipped up some trick removable plates to allow easy access of the shock canister. Still waiting for the proper canister mounts for the strut bar.
I'm not sure how you FD guys will do this without the canisters getting super hot thus changing the N2 pressure.
I bought a N2 tank from Roberts gas in Fairfax and a nice N2 gauge Longacre gauge: http://www.longacreracing.com/catalo...=1036&catid=19
Old May 20, 2010 | 03:28 PM
patfat's Avatar
Track junkie
I can't remember the FD engine bay, but could you do something like this?
