Cant get turbo to spool
Old May 3, 2010 | 10:15 PM
diamondotg's Avatar
Unhappy Cant get turbo to spool
I have a 1987 turboII with a 60-1 turbonetics turbo with a evolution wastegate and fmic.I also have a turbonetics boost controller and for some reason i cant get this thing to make any real boost.I have the boost line coming directly from the turbo and have the vaccum lines ran per the turbonetics instructions.Please help
Old May 3, 2010 | 11:19 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Disconnect the boost controller and run off the wastegate spring until you figure out how to use the controller. If an EBC isn't working, you hooked something up wrong or the settings aren't right.
Old May 4, 2010 | 08:59 AM
Aaron Cake's Avatar
Engine, Not Motor
What are you running for management? Any abnormal symptoms when you try to run it under boost? How much boost does it make?
Old May 10, 2010 | 09:36 PM
diamondotg's Avatar
it makes about 9 psi but u really have to rev it to get that like 6500 rpm or better
Old May 11, 2010 | 10:03 AM
Aaron Cake's Avatar
Engine, Not Motor
Pull the TID off and check the turbo by turning and wiggling the shaft. Is it stiff to turn? Does it move from side to side excessively?
Old May 11, 2010 | 11:25 AM
Top Down, Boost Up
Also, check/test for leaks in the intake piping and for exhaust leaks before the turbo.
Old May 11, 2010 | 11:47 AM
diamondotg's Avatar
i checked for leaks everything seems ok but there is a pretty good amount of shaft play is that a big problem?
Old May 11, 2010 | 01:12 PM
Top Down, Boost Up
Approximately how much play side to side or in/out?
Old May 11, 2010 | 01:57 PM
diamondotg's Avatar
if i had to give a mesurement maybe a little less than a half inch if that sounds right either way it has more play than i think it should have. The play is mostly side to side by the way
Old May 11, 2010 | 02:03 PM
diamondotg's Avatar
the turbo also makes kind of a shhhhh sound at idle
Old May 11, 2010 | 03:23 PM
Aaron Cake's Avatar
Engine, Not Motor
Half an inch?! That thing is dead. A little play would be about 1MM. At half an inch I would be expecting the wheels to hit the housings.
Old May 11, 2010 | 07:57 PM
Top Down, Boost Up
Half an inch is a hell of a lot of play.
Old May 13, 2010 | 03:55 AM
noddy89's Avatar
hows the blades on the shaft if its bent more then usual then thats another way to confirm you got too much play.
Old May 13, 2010 | 05:41 PM
diamondotg's Avatar
Nothing to worry about now car cut off yesterday and when i went to restart all the ic lines were collapsing so i took a look in the turbo and the impeller fins were gone so now i guess the search is on for a new turbo
Old May 13, 2010 | 05:59 PM
Top Down, Boost Up
Well that's a very bad thing. If the fins broke off, they're probably now inside the engine. Your search may need to include a rebuild kit now.
Old May 13, 2010 | 10:22 PM
RTRx7's Avatar
Rammer Jammer
It's a wonder you didn't hear it when they cam in contact with the engine.
Old May 14, 2010 | 10:15 AM
Aaron Cake's Avatar
Engine, Not Motor
With any luck, the fins are stuck in the intercooler.
Old May 15, 2010 | 05:24 PM
diamondotg's Avatar
going to get a new turbo think im going to get another 60mm what a.r exaust housing should i get?
Old May 16, 2010 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
What are the exact specs of the turbo you are looking at? 60MM could mean anything.
Old May 16, 2010 | 05:31 PM
diamondotg's Avatar
buddy of mine has a 60-1 turbonetics with a .96ar exaust housing i think that big of a exaust housing isnt going to spool good on the street what do u think?
Old May 21, 2010 | 09:52 AM
Aaron Cake's Avatar
Engine, Not Motor
60-1 is a good choice, and that exhaust housing is a good one. You might go SLIGHTLY smaller if you drive primarily in the city, but don't worry about .91 being laggy.
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Wolf_
Aug 11, 2015 04:23 PM
