Microtech timing issues
Old May 3, 2010 | 08:04 PM
john ward's Avatar
oi oi oi
timing issues
So i installed new freshly rebuilt engine cas marks perfect and it fires right up. I go to set timing lock it and it shows im about three inches away. Try to adjust it and she dies but runs great where its at with cas lined up right. I put light on t1 wire and its closer to mark than l1 is. I then rechecked wiring with ohmeter and i do have my leading and trailing coils correct. Someone please tell me what im stupidly overlooking. To try to get it lined up right im turning cas counterclockwise to the end of slot then she dies
Old May 3, 2010 | 08:11 PM
john ward's Avatar
oi oi oi
sorry im stressed and left out the main details. s4 turbo with a ltx8 stock coils with no ignitors
Old May 3, 2010 | 09:23 PM
rx72c's Avatar
Top Answer: 1
Needs more fuel in the idle map. When you retard timing it wants more fuel hence it stalls. richen the idle map up
Old May 3, 2010 | 10:17 PM
john ward's Avatar
oi oi oi
should i set timing and tps at where im going to run car at or at factory specs. Its running pig rich right now. Why would trailing be closer to mark than leading and me maxing out slot on cas to get ti line up? Ill try to richen up tomorrow and see what happenes.
Old May 4, 2010 | 04:20 PM
rx72c's Avatar
Top Answer: 1
It is normal for you to retard the CAS nearly all the way for the marks to line up.
USE L1 to line up your marks. NOT T1
Old May 4, 2010 | 09:59 PM
bumpstart's Avatar
talking head
unless its an FD !
Old May 4, 2010 | 10:40 PM
john ward's Avatar
oi oi oi
no i richened it up and i could retart the timng. im maxed out now about a 1/16 away from mark. should i change map or grind slot more on cas. rx72 u are the man. it does seem to load up alot now after richening though
Old May 4, 2010 | 10:50 PM
bumpstart's Avatar
talking head
you can restab the CAS one notch around ,, or you can use the timing trim on screen 30
-- firstly make sure you have no current value in the timing trim or in the static timing
Old May 4, 2010 | 11:05 PM
rx72c's Avatar
Top Answer: 1
Yes unless its an FD use L1.
Also show us a pic of how the CAS is stabbed and also make sure timing lock is on.
Old May 6, 2010 | 04:45 PM
john ward's Avatar
oi oi oi
yes timing lock is on even though it doesnt seem to make a difference on or not. I know to use l1 i was just making a statement that my t1 was closer to mark on cover. i threw another cas in and the marks now are only a hair away but still wont line up exact. I tried to install a tooth off and i cant advance it enough to get back to mark.
Old May 6, 2010 | 07:57 PM
bumpstart's Avatar
talking head
when its just out of reach you dive into screen 30 and adjust the timing trim value
Old May 8, 2010 | 02:24 PM
Lucrum's Avatar
Is this where the CAS is supposed to be with the e shaft pulley timing mark lined up?
Old May 8, 2010 | 05:19 PM
Lucrum's Avatar
After reading the manual again, I lined up the marks on the CAS shaft and gear then reinstalled the CAS with the e-shaft set pulley set to it's timing mark.
Is that correct?
Old May 8, 2010 | 07:48 PM
rx72c's Avatar
Top Answer: 1
that dosnt necessarily work. The two pictures showed have the CAS in the correct place.
Old May 9, 2010 | 05:54 PM
john ward's Avatar
oi oi oi
oddly i can advance timing with screen 30 but retarding doesnt change much. i drove today first time and have much issues with fuel. light acceleration is in 15's and cruise hits 17's. hard to check hard accel and stay out of boost though but it seemed in 13;s. is it normal to see 15's on an accel and around 5 inches of vaccum. laptop died while out so i guess ill richen up tomorrow
Old May 10, 2010 | 04:19 PM
rx72c's Avatar
Top Answer: 1
You want it around 14:1 in most of the cruise areas and bring it down to 13:1 at 00HG and go richer from their.
Queppa
Nov 18, 2024 03:47 AM
diabolical1
30
Jan 30, 2016 05:50 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
PhillyFC
Aug 21, 2015 06:36 PM
befarrer
Aug 14, 2015 04:18 PM
