Did a Search but I fail apparently. Modding S5 Taillights to fit on S4 Vert???
Old Apr 22, 2010 | 10:27 PM
ronnie416's Avatar
Bastardized RX7 Pwner.
The centre piece on the Verts have the key hole for the trunk. I need that!
I've never actually seen the differences between the way the two mount. (S4 and S5)
I've read that i need Vert Specific S5 lights with centre piece. Is there a way that I can just buy regular S5 Tailights from a hatch and modify them to work with my existing S4 Vert Centrepiece? If I had my hands on a pair I'd be able to see if I could modify them but unfortunately, I won't have my hands on any till I buy some!
Has anyone done this yet?
Thanks!
Sorry if this has been covered already.
Old Apr 22, 2010 | 10:30 PM
FelixIsGod29X's Avatar
Manual Rack
Not positive but I think you NEED the vert versions.
Old Apr 22, 2010 | 10:36 PM
ronnie416's Avatar
That's what I was afraid of. They're harder to find and seem to be a lot pricier.
Old Apr 23, 2010 | 01:41 AM
SouthSideSlider's Avatar
whats a Turbo V?
nah i've seen coupe S5s done. you loose your key setup on the trunk though
Old Apr 23, 2010 | 09:06 AM
Rob XX 7's Avatar
FC guy
if you want the key set up you need to keep the center section, they are interchangeable so if you cant find a s5 center it does not matter, a s4 will work with it no ZERO modifications.
S5 lights will also bolt RIGHT in to a s4, no modifications needed but its a little easier if you have the s5 bulbs with the s5 lights otherwise you have to dick with the s4s bulbs to get them in the s5 housings. Other then the bulb part they drop RIGHT IN, Im caps that statement because I always read about people bashing in metal here and there and its simply not needed or true, they will drop right in for the verts.
I had s5 vert lights on my s4 vert, then last year I went with coupe lights to change it up a bit, coupe lights require some metal to be trimmed
Spirit-RE's Avatar
You'd have to ditch the lock, drill some new holes, and possibly trim some metal back. Wouldn't be hard.
Old Apr 23, 2010 | 09:13 AM
ronnie416's Avatar
Good to hear it! Thanks for the reply. Just to clear it up a bit, you're sayinng that I can use ANY s5 tails with my original center piece? I need the lock there as my cables are shot.
If I find s5 vert lights, they bolt right in.
If I end up runninng regular hatch/coupe lights, I need to trim a bit of metal?
Is that right? Trimming, meaning I can trim with a dremel, right?
Sorry, have lots of wrench time but never with cosmetics.
Old Apr 23, 2010 | 09:16 AM
Rob XX 7's Avatar
FC guy
vert lights you can use your s4 center, but you need to stick with vert lights if you want to keep the trunk key function.
The metal you trim for coupe lights in a vert is not visible when the job is finished, you can use snips.
If you go S5 coupe lights you obviously need a whole s5 set up, and you would lose the key.
Old Apr 23, 2010 | 09:25 AM
ronnie416's Avatar
Cheers for the detailed information kind sir! I appreciate it.
Looks like s5 vert lights it is!
Thank you!
Old Apr 23, 2010 | 11:03 AM
Rob XX 7's Avatar
FC guy
transition from s4 vert, then s5 vert, then s5 coupe
Old Apr 24, 2010 | 01:46 AM
NoPistons!'s Avatar
Tango Down
Ah, ok. So all these people saying coupe tails wont fit verts and vice versa have been smoking crack all along, just as i suspected......
Old Apr 24, 2010 | 10:00 AM
Happy Meal's Avatar
I have a set of s5 vert tails if you are interested, pm me and we can work something out
Old Apr 24, 2010 | 12:27 PM
ronnie416's Avatar
Thanks for your help and THANKS you for those pics! I love the coupe tails but sadly, I need the lock.
You have one clean car! Thanks!
Old Apr 24, 2010 | 05:13 PM
Rob XX 7's Avatar
FC guy
the trunk will obviously still lock
you can easily rig a emergency release if the cable breaks
Old Apr 24, 2010 | 05:16 PM
ronnie416's Avatar
Yeah, my cable is seized already. Have to use the key as it is.
Old Apr 24, 2010 | 10:54 PM
Glass Machine's Avatar
Yes they have been and lots of it. I put 10ae tails on my 91' vert and all I had to do was drill 4 holes, cuz the centerpiece mounts just a little bit different place then the coupe's. Yes thats right I put S4's on a S5... get over it haha
Old Apr 27, 2010 | 05:02 AM
TheAbsence's Avatar
s4 Pride
http://www.aaroncake.net/RX-7/taillights.htm
Old Apr 27, 2010 | 07:39 AM
Rob XX 7's Avatar
FC guy
those instructions do not apply to convertibles, the sheet metal in the tailight area of a convertible is different then a coupe
Old Apr 27, 2010 | 11:51 AM
TheAbsence's Avatar
s4 Pride
I didn't know that, I love learning new stuff about our cars!
Old Apr 27, 2010 | 12:07 PM
Rob XX 7's Avatar
FC guy
its ok, the basics are the same, but putting coupe lights in a vert require more trimming then that
Old Apr 27, 2010 | 02:38 PM
More trimming? I did not have to any trimming just the 4 holes... But maybe I got lucky and it just fits.
Edit... ok am stupid haha sorry long day
Old Apr 27, 2010 | 02:41 PM
stevensimon's Avatar
coupe tails would work in your vert just fine if the 5.0 wasnt in there.
Old Apr 28, 2010 | 01:30 AM
NoPistons!'s Avatar
Tango Down
Some people like torque and better gas mileage.
Just saying......
David Hayes
13
Sep 5, 2022 12:45 PM
astrum
24
Nov 15, 2017 08:44 AM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
