Microtech s5 TII omp and lt-10s? and an injector question
Old Apr 20, 2010 | 11:02 PM
rotorhead_izzy's Avatar
Stewiefied Racing CEO
WI s5 TII omp and lt-10s? and an injector question
Hello to all who read this. I have a few questions. First of all the car and set up; I am about to start a s5 6 port turbo project using a microtech lt-10s and i was wondering if there was a way to run a s5 t2 electronic omp with this ecu? if so how do i wire it up?
Also have a question about injectors. since i'm going to use a lt-10s what injectors should i run, low or hight impedance? does it matter with this ecu? remember the car is s5.
Thanks in advance and any info will be greatly appreciated.
Izzy
Old Apr 21, 2010 | 02:45 AM
bumpstart's Avatar
talking head
Izzy
this ECU will not be worried by either saturated or peak hold injectors,, it will use either,, and also combinations provided its a primary /secondary differential
( though not recommended to do so as mix matching can make staging tricky )
this ECU CANNOT drive the EOMP
for that you have the usual fit the s4 timing cover and OMP or premix or aftermarket stepper controller running the EOMP
http://eomp.info
Old Apr 21, 2010 | 05:48 AM
Ok thanks. Do i have to do anything special to run either injector as in use resistors? As for the EOMP i'll just start to run premix.
Old Apr 21, 2010 | 05:19 PM
bumpstart's Avatar
talking head
it uses either,, without resisters
Old Apr 21, 2010 | 05:21 PM
ok, thanks
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
