Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
2jz FC
Old Apr 20, 2010 | 07:53 PM
rotary-guy's Avatar
2jz'd fc
2jz FC
so i got tired of rotarys due to my last build. so im going a different route, i have my 2jz sittin in front of my 89 TII,
whats in the car as of now from the last build that will stay is
aeromotive a1000 fuel pump and regulater (-10an from tank to pump, -8an from pump to fuel rail, -6an from the regluater back to tank), greddy fmic, inovate water temp, oil pressure, and boost guage as well as wideband.
stuff i have for the motor already
-garrett gt40 turbo
-twin tial 44mm wastegates
-6x 1000 cc injectors
-rear sump oil pan and pick up off of a 1jz
-4in builders kit for my exhaust
-1jz 5speed R154 trans
-full rebuild kit
-arp head studs
-pilot bearing
stuff needed still
-fuel rail
-tubomanifold (will be making)
-standalone, this im not sure about, lots of choices. someone point me in the right direction please lol
-clutch set up + flywheel (***** expensive ughh)
-custom drive shaft
ill start posting pics as soon as i really start to work on this project as im finishing up a v8 project at the moment as well.
lets hear what you guys think
Old Apr 20, 2010 | 08:53 PM
fstbckgt's Avatar
Barrel Roll
i wanna see how you deal with the motor height issue of the 2J, dry sump or huge hood bulge
Old Apr 20, 2010 | 10:09 PM
rotary-guy's Avatar
2jz'd fc
oh i plan on droping the subframe just like doin a v8 swap, then building my mounts as low as possible, ill see when i get there really. i have hoods galore so i can destroy them if need be too lol. i didnt think it was "that" much taller than a 1j
Old Apr 21, 2010 | 11:25 AM
digitalsolo's Avatar
RX-347
V8 FCs don't alter the factory subframe, FYI.
Old Apr 21, 2010 | 01:41 PM
NoPistons!'s Avatar
Tango Down
You could raise the back of the hood with spacers, cut the hood and put a drop vent in for more clearance or just cut the skeleton and see where that gets you.
It should be fine.
Old Apr 21, 2010 | 03:24 PM
fstbckgt's Avatar
Barrel Roll
droppin the subframe or lower mounts def seems like a cheaper option than dry sump, cant wait to see it done...and ya the angle of the pistons on a V8 make it short enough to clear a NA FC hood, inline 6s are just taller
Old Apr 21, 2010 | 06:49 PM
rotary-guy's Avatar
2jz'd fc
yes you do...with ford 302 fuel injected motors, i know cause i just did that swap in another car lol. not all v8's require it yes but some do.
im gonna deal with this clearance issue when it comes up, hopefully i dont have to do more than take out some skeleton support in the hood but ill see
Old Apr 21, 2010 | 08:01 PM
ehime's Avatar
肉*食*系*
Honesty Earl all you really need is an 0.5"-0.75", it's not really that bad.
Most of the swaps I've seen don't even drop the frame, they just notch
it and re-weld a top plate. Most of the Supra guys end up with a MoTech
standalone, it just seems to be whats popular with them. I've seen quite
a few people in Japan use engine shock dampeners instead of the pricier
gas shocks for propping the hood (I think Top Secret and a few others
sell them for nonspecific car apps.). You can get dampeners for around
35$ per, then make your own brackets.
Old Apr 22, 2010 | 04:13 PM
Bobbo's Avatar
lost another one to the dark side..... another 7's soul has been destroyed
Old Apr 22, 2010 | 10:16 PM
rotary-guy's Avatar
2jz'd fc
lol why even look in the other engine conversions section then??
on another note, got all the manifolds off the motor, taking the twins off is a pain in the *** ill tell you what. i also checked out what would be my clearance issue and all i can really see is the front sway bar.
Old Apr 22, 2010 | 10:29 PM
Spirit-RE's Avatar
I've always have been intrigued by 2j swaps in FC's, would make an excellent reliable DD.
Good luck with the build.
Old Apr 27, 2010 | 10:54 AM
drama's Avatar
DRAMA
Am getting ready to do a 2JZ swap to my 89`T2 also. I have my 10th A.E car with a Fd swap. So why not play with a toy motor, I have a good friend of my with a 97` Supra and And small single 60-1, Big intercooler, HKS evc, Carbon-carbon twin disk, hks ignition, we`ve beat the hell out of this car and it still runs like a raped ape, Just change the plugs and oil and keep beating. Am ready to abuse a car like that for my own, even most best built rotarys can`t take the abuse we`ve give this car, Oh did I say the rear end blow once. with slicks.
Hell I say go for it, and GOOD LUCK with your build.
Old Apr 27, 2010 | 01:43 PM
NoPistons!'s Avatar
Tango Down
Because he loves hard dick, trolling and hating.
It is a pain Oem turbo/manifold studs suck.
Old Apr 27, 2010 | 03:14 PM
fstbckgt's Avatar
Barrel Roll
^ indeed
Old Apr 30, 2010 | 02:10 AM
NoPistons!'s Avatar
Tango Down
And holy ******* **** check this out!!!!!
https://www.rx7club.com/other-engine-conversions-non-v-8-118/everyone-read-other-engine-conversion-forum-rules-400819/
Who knew?
New rule should be "you will be ******* BANNED FOR LIFE for talking such **** in this section"
jz motors are just uber ejaculatoryfantasmgastic. Haters just dont know.
I actually want to see more crazy motor swapping, not less due to people being ******* and making the internet suck harder than it already does.
Old May 1, 2010 | 05:59 PM
Cam_Ron's Avatar
I'm doing a 1jz swap into my 88 TII AE and I can tell you that even with the engine as low and as far back as I can possibly put it (1/4" between the pan and the subframe), its going to be really close for hood clearance. This is with me cutting the reinforcements out on the underside.
I was considering the 2jz myself, but from my measurements its just under 2" taller than the 1jz. If your going to lower the subframe, be sure to space the steering rack back up to the original height if at all possible. If not be prepared to deal with some bumpsteer.
Old May 2, 2010 | 03:46 PM
rotary-guy's Avatar
2jz'd fc
im about ready to start mocking up the mounts and lookin at all the hight issues, just need to pull the autotrans off and put my manual trans on then is mock up time. once i get everything mocked up im going to make my mounts at work and have my head resurfaced as im taking it off anyways to install my arp head studs. more to come with picutures in the next week or so.
-Earl
Old May 12, 2010 | 03:09 PM
sexy*rexy's Avatar
Got the same swap going in to my fc... Wondering how the hood is going to fit.. haha
Old May 12, 2010 | 11:00 PM
rotary-guy's Avatar
2jz'd fc
ehh it will fit somehow, still finializing my v8 project then this swap will really kick into gear
Old Jun 4, 2010 | 06:09 AM
xerospeed's Avatar
CHECK ENGINE
in for interest as I am looking into a JZ-swapped FC
Old Jun 4, 2010 | 06:08 PM
rotary-guy's Avatar
2jz'd fc
havent really worked on it yet, just finished the current project, so now i can hopfully start on this one
Old Jun 4, 2010 | 07:27 PM
Vierte's Avatar
you can also cut a 2jz sized hole in the firewall and move the motor back a little. that requires some sheet metal work to enclose the firewall... and it makes it a pita to remove the valve cover but its till possible.
Old Jun 5, 2010 | 10:14 PM
rotary-guy's Avatar
2jz'd fc
thats what i do for work, im a pressbrake opertor and sheet metal worker so thats a more than do able option for me.
Old Jun 11, 2010 | 05:10 AM
clint999's Avatar
Old Jun 11, 2010 | 06:01 PM
rotary-guy's Avatar
2jz'd fc
huh? you quoted but no response yo, other project (if thats what the question was gonna be) was a FI ford 302 in a 88 gxl which is probably sold this weekend too
just bought my act prolite flywheel
