Number 2 Water Temp Switch (Rad)
Old Apr 18, 2010 | 05:08 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
So I am looking in the FSM and I have the number 2 water temp switch plug. I can't
find the plug anywhere on the radiator. The only wire from the radiator is on the top
censor, which I believe is the low coolant sensor. I know one of the water switches
fell off, the one on the back of the water pump housing.
Blue with black stripe, and a blue with yellow stripe wire.
#b11
Old Apr 19, 2010 | 11:59 AM
Jeezus's Avatar
Bump!
Old Apr 19, 2010 | 12:21 PM
t_g_farrell's Avatar
Waffles - hmmm good
The sensor on an SA radiator is on the drivers side upper, right under the
radiator fill. On an FB its on the drivers side lower, at the very bottom of the
radiator. Both sensors thread in horizontally and stick out of the radiator on
the fan side.
Either way these are just for the cold start assist which I'm sure your
not using anymore.
Old Apr 19, 2010 | 01:28 PM
j9fd3s's Avatar
Community Builder
the EFI cars use this switch to "turn on" the emissions system.
sherff
Feb 24, 2019 12:09 PM
Snoopy FD
Dec 8, 2015 01:45 PM
josef 91 vert
Aug 29, 2015 12:22 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
