Megasquirt My '83 Project: MS2 3.57 with Zeal
Old Apr 16, 2010 | 08:21 PM
afterburner16's Avatar
the Appleton Don
I have read both pinned threads by muythaibxr. I have read through Aaron Cake's Megasquirt info on his site. I have also read through the info at http://stuff.pw.cx/Megasquirt%20MS2%...azda%20CAS.pdf. However, I'm still a little confused.
If I read it all correctly, all of the info and pics are directed at MS1 computers. I have an MS2 3.57. I bought it preassembled and I also bought the Zeal Engineering VR daughterboard and assembled it myself. My question is how do I combine them now to work together so that I can wire up my ignition system. I am planning to run the stock FC CAS (untouched) and FC coils.
Any help will be appreciated. I can supply pics if needed.
Thanks.
Old Apr 19, 2010 | 02:41 PM
muythaibxr's Avatar
MegaSquirt Mod
Aaron Cake's howto at the top of the MS section tells you how to do it for ms2. Just follow that one.
Ken
Old Apr 20, 2010 | 09:39 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't cover the 3.57 and Zeal just yet because I have not had my hands on them. The inputs and outputs are the same though. Wire the VR conditioner on the Zeal to the same place you would wire the LM1815 circuit. The 3.57 has pullup resistors already on the LEDs so wire those to the DB37 as my writeup specifies. Then wire the VR inputs on the Zeal to the DB37.
Old Apr 20, 2010 | 04:07 PM
the Appleton Don
I've done some searching around and I found THIS and some other info on the Zeal instruction page, so I'm trying to work through that information and get to soldering. It looks like I only have about 12 places to solder. 3 of them are jumper wires to PADs 1, 2, 3, 12, 14, and 16. The rest are as follows:
12v - S12
5v - S5
Gnd - Proto Gnd
Gnd - SG
VR2+ - PAD15
VR2- - PAD13
VR2 Out - JS10
IN1 - JS11
OUT1 - PAD11
Note* this is info straight from the page, so I am not the author.
It looks likes it may easier than I thought, but I do have a few questions. First, JS10 is already occupied, so should I connect VR2out there anyway? Second, I don't have a Proto area on my board, so where do I put the Proto Gnd? Third, I don't see any LEDs on my MSII, so what LEDs am I looking for? I just don't want to mess up the computer before I get the chance to use it.
Thanks for your help guys.
Old Apr 21, 2010 | 11:32 AM
muythaibxr's Avatar
MegaSquirt Mod
What is JS10 occupied by?
The LEDs are the three on the front of the main board.
Ken
Old Apr 21, 2010 | 05:56 PM
diabolical1's Avatar
Ken
hi muythaibxr (Ken),
i'm working on this project with him. JS10 was a jumper wire to Q16's middle slot, though i don't know what it's actual purpose was. you can disregard what afterburner16 said, the instructions said to remove it, so i did. when i get a desoldering iron to remove the leftover remnants of the previous connection, VR2 OUT will go there as instructed.
as of this writing, i've done most of the connections listed. the only part that is left somewhat of a puzzle is the Proto Ground area. i still haven't located it. i do see a spot with 4 slots (ground x 2 and 5v x 2) just below the H1 jumper, so i think that may be the 3.57s Proto ground area. basically i ran out of wire today, so after i go to Radio Shack tomorrow, the Zeal should be totally installed and hopefully (fingers crossed) ready to go soon as i finish wiring the car.
however, about the LEDs, i can vouch for there not being any on this unit. just for the sake of us being on the same page, i am actually looking for red LEDs (like what i've seen in so many MegaSquirt photos) and not something else, right?
Old Apr 22, 2010 | 09:47 AM
Aaron Cake's Avatar
Engine, Not Motor
The 3.57 uses tiny surface mount LEDs, and already has pullup resistors with pads ready for soldering.
In the following image they are D154, D16 and D14 at the left:
From the Megamanual:
"The three front-panel LEDs have been converted to surface mount devices. These cannot be easily viewed through the standard LED end-panel holes, but are easily visible with the case lid off. If front-panel LEDs are desired then the surface mount units are removed and jumper wires installed in place. Also, since the LED drivers are often used for alternative output applications with the spare outputs, there is a new 1K Ohm pull-up resistor connected to the driver transistors, and this connection is available on the PAD1, PAD2, and PAD3 PCB terminals (see schematic for details). "
Old Apr 22, 2010 | 01:28 PM
thanks Aaron,
i located them with your post and, they are, indeed, there. the only reason i don't feel like a complete dumbass is because i was able to reason with myself and realize that i don't do this stuff everyday, so LEDs have managed to come a long way since i did this on a regular basis.
anyway, i got my desoldering iron a few minutes ago and i'm going to work on this thing. i hope i'm right about the Proto Ground spot. i'd love to hear from you or anyone that may know. i'll go check the Megamanual that you quoted above, as i see there has been some new information i have not seen.
Old Apr 22, 2010 | 03:39 PM
RX-Mini's Avatar
You are right regarding the Proto ground spot! Just did the v3.57/Zeal conversion on a FD, and made it work. We found an error in DIY's write-up, so if you follow that be aware...
JP1 should be in the 1-2 position to enable the VR circuit, not 2-3 as they tell you.
Old Apr 22, 2010 | 04:16 PM
thanks, man. i had to go back and move that jumper that you mentioned, but so far all is good as far as i can tell. hopefully i can get the car wired bay the middle of next week (i still need to get a fuse box and satisfactory common grounding point) and then it's just a matter of loading the software and trying for the first start.
Old Apr 24, 2010 | 06:36 PM
the Appleton Don
Well, we got some work done today. Have a few questions just to doublecheck with more experienced people. I think we made good progress with wiring and this is how we have it. We saw a slight difference in the www.diyautotune.com and Aaron Cake diagrams, so we went with the diyautotune diagram since that's what we used to build the Zeal board.
G+ = pin 25 (blue/white IAC1A)
G- = pin 27 (blue/white IAC1A)
Ne+ = pin 24 (have not located it yet)
Lead coil red wire = pin 36
Trailing coil red wire = pin 31 (green/white IAC2A)
" " " white wire = pin 29 (green/white IAC2A)
" " " black wire = tach signal (on the car's harness)
Does this look right as far as the ignition system goes? Thanks.
Old Apr 25, 2010 | 09:59 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no right and wrong, you can use whatever spare pins for whatever signals you so choose. I tend to use the spare outputs and IAC pins for extra I/O and avoid moving around the "stock" pins like ignition to prevent confusion in the future.
Why do you need the tach wire?
Old Apr 26, 2010 | 09:48 PM
as far as i can tell, it's the only way the tachometer will get a signal to work with. am i correct? is there another way to do this?
Old Apr 27, 2010 | 03:26 PM
muythaibxr's Avatar
MegaSquirt Mod
The tachometer on the 2nd gen rx7 is driven from the trailing ignitor.
Ken
Old Apr 27, 2010 | 04:23 PM
RX-Mini's Avatar
You got the V3.57, right? I followed the instructions from DIY and used the DB15 connector... Seems like you are following the instructions for connecting the V3.0 and NOT the V3.57.
http://www.diyautotune.com/tech_arti...zda_fc_rx7.htm
Function: Stock wire color: V3.57 connection
NE +: Red : DB37 Pin 24
NE - :White : GND (DB37 pin 2 on our harness)
G + :Green :DB15 pin 3
G - :White w/ black stripe :DB15 pin 4
Leading coil 12V :Tan :12 volt switched power
Leading coil IGT: Red :DB15 pin 10
Leading coil ground: Black :Engine GND
Trailing coil 12V: Tan (2 wires) :12 volt switched power
Trailing coil IGT :Red :DB15 pin 11
Trailing coil select: White :DB15 pin 12
IGF :Yellow :Not used by MS
Trailing coil tach signal: Black :To tach
Old Apr 27, 2010 | 06:42 PM
as far as i know, so is the tachometer of the Gen I. however, i have to marry the Gen II coil/ignitor assembly to a Gen I car.
Old Apr 27, 2010 | 07:48 PM
aye. aye. aye. you know what? you're absolutely right. it looks like i screwed up the wiring. for the record, yes, he has a v.3.57, not a v.3.0.
he bought the 12-foot DB37 harness and i thought that everything had to be fed through that because it's the only wiring harness he got. i assumed the two ports on the other side of the case were to be used when we started tuning. i didn't realize that the DB15 that i kept seeing mentioned in the diyautotune instructions was one of those two ports. so it looks like i'm going to have to have him order a connector/harness for the DB15 port, and then proceed with wiring from there.
Old Apr 28, 2010 | 09:24 AM
Aaron Cake's Avatar
Engine, Not Motor
Just connect the 1st gen tach to the yellow/blue wire on the leading coil plug. It will work.
Old Apr 29, 2010 | 06:17 PM
the Appleton Don
What are you guys doing for DB15 connections? I didn't see anything at the DIY site and the only thing I see on other sites are basically VGA cables. Should I just buy one and cut it up?
Old Apr 29, 2010 | 08:40 PM
muythaibxr's Avatar
MegaSquirt Mod
At this point I'm using the MS3 on a normal v3 board on my rx7 (well was before I took it apart to replace the rear main seal, clutch, pressure plate, and transmission). So I'm not using the DB15 at all.
Ken
Old Apr 30, 2010 | 11:13 AM
for anyone interested. we found some at THIS SITE. however, i'm going to check with a local guy later today, if that doesn't work out, then i'll have afterburner16 place an order.
Old Jun 26, 2010 | 10:23 AM
update time:
okay, as far as i can tell, i'm done with wiring and i'm trying to load the initial flash to the ECU. this process has been going painfully slow because of time and also because i guess i'm not as computer-savvy as i thought.
anyway, i have both MegaTune 2.25 and Tuner Studio loaded on my laptop, but i'm falling short on how to get either (or both) loaded on the MegaSquirt. i hate to seem like an idiot, but here i am. also, my JimStim construction got messed up, so i'm stuck doing this the hard way. however, if worse comes to worst, then i may just bend over and order another JimStim (i basically wrecked the processor, so i figure the board is now useless).
for now, if you guys can help me sort through this stuff, it would be great. if not, no worries either. thanks.
these are the sites i'm using to try get through this:
http://www.aaroncake.net/RX-7/megasquirt/ProgramMS2.asp
http://www.megamanual.com/megatune.htm#install
http://www.ideasandsolutions.biz/TunerStudio/download/
the problem is i can't seem to find/see the files that should help me install it on the ECU.
Old Jun 28, 2010 | 05:55 PM
muythaibxr's Avatar
MegaSquirt Mod
Neither megatune nor tunerstudio install on the MS. They are tuning software not firmware.
You need to go download a firmware image from the firmware thread and use the .bat file contained in that to load the firmware over the serial port to the MS.
Ken
Old Jun 30, 2010 | 11:00 AM
thanks for that correction muythaibxr, i guess i had always used "firmware" and "software" interchangebly, i now know the difference. at any rate, i still didn't realize that MegaTune and Tuner Studio didn't have to be on the ECU.
i think i was successful in installing the firmware, and i think i was also successful in setting up some of the general parameters. i will continue to work on setting up the parameters and trying to find an honest-to-goodness .msq-file to load as an initial tune.
Old Jul 2, 2010 | 09:02 PM
okay, well i spent the day trying to get it fired to no avail. i'm still searching through threads to find out why i'm not getting any spark. my guess is miscommunication (or no communication) between the MSII and the crank angle sensor, but i have yet to figure out how to confirm that.
at any rate, the only question i have at this time is: in the Ignition Options table, where everyone says to set the Spark A output pin to D14, should i select JS10 (because i'm using the 3.57 and Zeal, and i followed the DIYAutoTune instructions for wiring with the DB15)? so far i have tried both settings and neither one yields spark at the coils, but i want to make sure i'm starting with the right setting as i try to troubleshoot.
i've gone over the wiring several times. as far as i can tell, everything is as it should be.
this is a useful thread for me (pay no attention): Rx7 Mini thread
