gt35/40 installation
Old Jun 20, 2002 | 01:03 AM
AJatx's Avatar
I fabricated a downpipe with mild steel elbows and a flex joint. I hope it lasts since it's my first hack at welding.
Old Jun 20, 2002 | 01:05 AM
AJatx's Avatar
Here is a pic of the old downpipe (previous owner), my downpipe, and HKS manifold with T4/T3 adapter flange welded to it.
Old Jun 20, 2002 | 01:08 AM
AJatx's Avatar
HKS Manifold after the HKS T3/T4 adapter was welded on the original T4 flange.
Old Jun 20, 2002 | 01:09 AM
AJatx's Avatar
View of the ugly welds inside the flange adapter.
Yes, I know the welds will disturb the exhaust pulse flow. I need to smoothen the weld out.
Old Jun 20, 2002 | 01:13 AM
AJatx's Avatar
Fitting the exhaust manifold on block.
Old Jun 20, 2002 | 01:15 AM
AJatx's Avatar
Fitting the turbo on the manifold.
Old Jun 20, 2002 | 01:16 AM
AJatx's Avatar
more...
Old Jun 20, 2002 | 01:21 AM
AJatx's Avatar
Clearance from the frame to the turbo wasn't much, but it's enough.
Old Jun 20, 2002 | 01:22 AM
AJatx's Avatar
Fitting the downpipe on the turbine outlet flange.
Old Jun 20, 2002 | 01:23 AM
AJatx's Avatar
Fits pretty good with the rest of the exhaust.
Old Jun 20, 2002 | 01:28 AM
AJatx's Avatar
Entire mock-up (different from final in a few ways).
You'll notice the J-spec lower intake manifold was used since the EGR cast in the manifold hit the top of the turbine housing.
I switched around the water line fittings.
I will hate removing/installing this set-up again since everything is so hard to access.
J
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
