carbed my fc, want to run 1st gen ignition
Old Apr 14, 2010 | 03:09 PM
revox7's Avatar
Rotary AE86
Exclamation carbed my fc, want to run 1st gen ignition
hey guys ive posted this up on alot of other performance threads but get no response
i have an s5 fc with a 6 port 13b im running mikuni 48 with a RB manifold, so since i cant use the fc ignition system i got a 1st gen dizzy ignitors and plug wires to put on the car the only problem is that i have no clue how to wire it up has anyone done this? and if you can help out itd be very much appreciated, thank you in advance
ps this is a track car so smog isnt a problem
Old Apr 14, 2010 | 03:15 PM
food7373's Avatar
Kid
Got any pics of the engine with the carb, I want to see it. Sorry I don't know how to wire it either, I'm sure some one does on here.
Old Apr 14, 2010 | 03:28 PM
AcidAngel7477's Avatar
We're All Fkd..
wackyricer would know something about this..im sure he will chime in when he sees it.
:AA:
Old Apr 14, 2010 | 04:21 PM
revox7's Avatar
Rotary AE86
Thanx guys. ill post some pix in a bit, its not very pretty at the moment but as soon as it starts im going to start cleaning it up
Old Apr 14, 2010 | 05:08 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
I wouldn't mind taking a look for ya. Gotta download the FSM for the S5's then I will peek at it.
If I were you I would keep the 2nd gen leading coil pack instead of reverting to 1st gen coils.
The 2nd gen coils are a noticeable upgrade coming from stock coils. IIRC you just gut the
leading ignitor and solder the 2 outsides together and the 2 inside tabs together. Not sure if
this is for the 2nd gen coils or for MSD setup, I've had too much ignition changes lately
Old Apr 14, 2010 | 05:52 PM
revox7's Avatar
Rotary AE86
Ill take my coil off and look at it if you can be sure about cutting and soldering is on the stock 2nd gen then ill go ahead and do that.
Old Apr 14, 2010 | 06:30 PM
bwaits's Avatar
Needs More Noise
A good bit of the first gen guys run second gen coil for leading and a first gen coil for trailing. Easiest way is to use an electronic dizzy from an 81-85. These have the igniter built onto the housing.
On the Fc leading coil remove the wires running from the mounting base going up to the pos and neg post. See picture, Red X is the wires to remove.
Run a switched 12V to the positive terminal on the FC coil and first gen coil.
Run a wire from the positive of the FC coil to the plug on the igniter closest to the front of the car. There are two terminals in the shape of a "T", use the top of the "T".
Run a wire from the positive of the first gen coil to the igniter plug closest to the alternator. There are two terminals in the shape of a "T", use the top of the "T".
Run a wire from the neg of the FC coil to the igniter closest to the front of the car. Use the vertical terminal of the "T" shape.
Run a wire from the neg of the first gen coil to the igniter plug closest to the alternator. Use the vertical terminal of the "T" shape.
Run the plug wires from the first gen coil to the "leading" spot on the dizzy cap.
Run the plug wires from the leading 1 and leading 2 spots on the dizzy cap to the trailing spark plugs.
Run the plug wires from the FC coil directly to your leading plugs.
The car will run. Not sure how to hook up the tack on a FC. If you find the correct wire in the FSM you can run it to the negative of the coil.
Makes sure your switch 12V source also has power when the key switch is in the start position as well as the on position.
And yes, I have the plug wires listed correctly for the trailing. By using the leading side of the dizzy cap and rotor button you will see better spark.
Old Apr 14, 2010 | 06:51 PM
Siraniko's Avatar
RX for fun
bring it over to me, near Dodger Stadium in LA.
Old Apr 14, 2010 | 06:52 PM
revox7's Avatar
Rotary AE86
holy crap that sounds easy as hell
Old Apr 14, 2010 | 06:55 PM
revox7's Avatar
Rotary AE86
its not running at the moment and i have no way to get it down there
Old Apr 14, 2010 | 07:37 PM
Siraniko's Avatar
RX for fun
pmd ya my #
Old Apr 14, 2010 | 07:46 PM
Jeezus's Avatar
pmd ya my #
You never pm ME your number
Old Apr 14, 2010 | 07:50 PM
Siraniko's Avatar
RX for fun
so you can call me in the middle of the night with heavy breathing lol
Last edited by Siraniko; Apr 14, 2010 at 08:03 PM. Reason: posted my # as a teaser
Old Apr 14, 2010 | 07:51 PM
Siraniko's Avatar
RX for fun
I did the FC coil direct fire (without MSD 6A or 6AL). its ok but IMHO, not a significant improvement over stock.
Old Apr 14, 2010 | 07:55 PM
food7373's Avatar
Kid
lolol
Old Apr 14, 2010 | 09:04 PM
revox7's Avatar
Rotary AE86
im going to just use the stock fb set after i get it running RIGHT ill continue to doing the direct fire setup using an msd system THANKS TO ALL WHO POSTED TO HELP ME OUT ILL BE SURE TO KEEP YOU GUYS UPDATED, THANKS TO WACKYRACER FOR THE OVER THE PHONE STEP BY STEP AND BWAITS THANK YOU FOR THE STEP BY STEP WITH THE PIC
Old Apr 18, 2010 | 04:54 PM
revox7's Avatar
Rotary AE86
here are some pix of what i have so far
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Joe428
16
Aug 19, 2015 06:24 PM
Marty RE
Aug 13, 2015 11:19 AM
